anyone out there every get water in oil from exhaust sucking back??
How is it even possible for water to get into the oil from the exhaust, I understand revision but that usally doesnt cause water in oil.
Op do you have a oil cooler by chance? Could this oil cooler have a crack in it?
If you had enough revision to get water in the oil I think you would have a very rough running motor at idle.
Just my 2 cents
Just my 2 cents
Intake manifold or gasket. but the oil cooler is also possible. It would take a lot of water for a very long time to get thru the piston rings into the block or to go against gravity and thru a valve seal into the head.
Fast Singles Club
Just my 2 cents
Just my 2 cents
Skip the voodo science and pressure test it . Pull the dist and take a peek with a mirror and look for witness marks and seep in the valley . Verify your not dumping 3800gpm in the exhaust at idle from the problem motor .please do tell us what you have found . Reversion will get you water in oil . If you have robust valves that can take the beating. But yea peek up the butt ,motor off ,make sure you dont have a problem where the tail water releases.
