Oil Filter Question
Charter Member #34
Oil Filter Question
What oil filter do you guys use for the 500 EFI.
My dealer is out, I went by a local marina and the ones they sold me are shorter than the Mercury filters. Not sure I want to do that?
I would like to find a good quality filter that I can get at a local Napa.
If anyone has had good luck with one and knows the part number please let me know.
Mark
Mark
Doc: call me about the ride to jax. i am home now! also you might want to consider using the fram hp4 filter. advance auto carries them here! i wouldnt use a standard automotive fram though. i had one break on the inside and alost cost me an engine. the hp fram and k&n are performance type!!
Toxic FORMULA
I've seen Fram collapse I usually use the GM Delco 2 Quart filter , Wix also make the same and both are good quality .Also gives you an extra quart for c ling
Forum Regulator
NAPA 1061R
(Wix Racing Filter)
Best on the market.
(Wix Racing Filter)
Best on the market.
