Nothing left to check?  VP 5.7GSI wont start - good fuel pressure, good ecm, wiring >
Old 05-21-2015, 03:33 PM
  #271
I will do that with my timing light on Saturday if the new injectors (GM 25170301) don't solve it.
I also will have the diacom tomrorow night which will help.
nunnink23 is offline
Old 05-21-2015, 06:57 PM
  #272
SB
Received 3,227 Likes on 1,456 Posts
Fact: (info from Delco) ACDelco #217-2282 is GM#19110534
Supposedly Supersedes:
AC Delco 217-348 and GM Part Number 17113080,
SB is offline
Old 05-21-2015, 07:02 PM
  #273
ULTRA-POWER Part # TJ17 New
New Throttle Body Injector; Sierra
New Fuel Injector; Sierra (Only 6 Remaining)
Part Image
$45.79 $0.00 $45.79
STANDARD MOTOR PRODUCTS Part # TJ17 {Click Info Link for Alternate/OEM Part Numbers} Throttle Body Injector; w/ O-ring One of our most popular parts
Part ImageNext Image
$75.79 $0.00 $75.79
ACDELCO Part # 2172282 {Click Info Link for Alternate/OEM Part Numbers} Professional
$150.89 $0.00 $150.89
AIRTEX / WELLS Part # 4G1794 {Click Info Link for Alternate/OEM Part Numbers}
17113080, 17113081
$288.89 $0.00 $288.89
Remanufactured
AUTOLINE Part # 15916 Reman
Injector
Part Image
$27.79 $30.00 $57.79
GB REMANUFACTURING Part # 83114117 Remanufactured T/B Injector
Part Image
$27.79 $35.00 $62.79
Fuel Injector O-Ring
All kinds of crosses there damm.
Tail_Gunner is offline
Old 05-21-2015, 07:17 PM
  #274
I'm getting so confused lol. Do you guys think the 25170301 injectors from GM are the wrong ones then? It seems like all the numbers you guys are mentioning are related to the TJ 17
Old 05-21-2015, 07:25 PM
  #275
Dont be confused they all have one common denominator 50lb injectors@13 psi or close to that and 94/95 454 engine's that use a 30 psi fuel rail.
Old 05-21-2015, 07:28 PM
  #276
Gotcha. If these work then we will all have learned a lot. Hopefully they do work, because there is absolutely no info on what injectors replace the VP TBI injevtors. At least from this model, which is pretty common.
Old 05-21-2015, 07:29 PM
  #277
SB
25170301 is # on injector. But What is the actual GM or Delco part # ? That is the question.
The #'s I gave above are part #'s...not the # stamped on the injector.
This is what add's to the 5 million # confusion. LOL.
SB is offline
Old 05-21-2015, 07:31 PM
  #278
SB
Correct.
If you go to Delco's site via my link and click applicaations, it lists 94-95 454 trucks which use 30lbs, and it also lists 94-95 5.7 trucks which use 10-13psi.
So............maybe GM used a 1 injector fits all for 94-95...in regards to the top selling tbi's...being 5.7's and 7.4Ls.
Maybe we figured something out ? LOL.
And yeh, my head hurts too.
SB is offline
Old 05-21-2015, 07:32 PM
  #279
Originally Posted by sb
25170301 is # on injector. But what is the actual gm or delco part # ? That is the question.
The #'s i gave above are part #'s...not the # stamped on the injector.
This is what add's to the 5 million # confusion. Lol.
omg......
Old 05-21-2015, 07:57 PM
  #280
Correct.
Actually from a few phone calls what i was able to gather they could not get uniform repeatabilty @ 30psi...remember they had to conform to govt epa stds and that was a 5/50 mile warranty std back them (emission warranty) So guess who picked up the ball...marine nice little pkg on size fit's all..no epa std's and high pressure high performance injector's or so the story goes...
