Nothing left to check? VP 5.7GSI wont start - good fuel pressure, good ecm, wiring
#281
Yes, The super low compression 454's had a hard time with emissions..........thus the higher fuel psi's for 94/95.
#282
Play with the cross reference # on acdelco's site. I put in TJ17 and one of the AC Delco Injector's was 217-2282 that I mentioned a an hr or tewo ago.
#283
Actually from a few phone calls what i was able to gather they could not get uniform repeatabilty @ 30psi...remember they had to conform to govt epa stds and that was a 5/50 mile warranty std back them (emission warranty) So guess who picked up the ball...marine nice little pkg on size fit's all..no epa std's and high pressure high performance injector's or so the story goes...
SB - would it be reasonable to say I can buy an adjustable regulator from you, and tune the fuel flow a bit? Let's say it runs almost prefect, but seems a bit lean, can I crank the pressure up a PSI or two? Probably not I assume. But how about the opposite? Can I run lower pressure of I find out that they are running too rich?
#284
With Volvo's Does the regulator in the tbi unit actually govern fuel psi, or is there another regulator in the system (like Merc sometimes uses) that overides it ?
#285
As far as I know it's only regulated by the tbi. I believe the pump will put 30 psi out no matter what though, since I've heard checking the pressure directly at the pump outlet (capped off) will read 30 psi or so.
I don't think I can increase fuel pressure at all, but I should be able to decrease it, unless it ends up causing the fuel cell to overfill and come out of the vent tube into the intake.
#286
They run a rochester 220 style with a fixed 30lb spring in there....yes you can put a adjustable reg in there no problem but with a gauge at the very least how are you going to know what the afr your burning at or is someone going to read plugs for you...
#287
Hopefully it doesn't get to that point
#289
Alright gents, I have the Diacom tool in my hands. I do not have a tracking # for my injectors, but I hope they will be in today. Any specifics I should be looking for on Diacom? I will post back what I find, and hopefully my injectors come today and put an end to this.
Have a great memorial day weekend BTW. Hopefully everyone else is boating!
#290
34F here right now. 20+mph winds. Both boats are still in shrink wrap. I do hear a few boats out there. Probably marina guys delivering boats or people going to their island homes. Brrrr. High of 59-60F.
Diacom, Coolant temp, MAP, TPS, and timing are the big ones. BUP would have to give you what readings they should be at idle and etc.
Good luck this week-end.
