Crossover question???
puder
Make sure you run the correct thermostat for a cross over set up.The thermostat has small bypass holes in it ,to keep it from constantly opening and closing due to the cold water entering thru the bypass.
I have a solution for the water pressure problems that come with high speed and crossovers. For 100 bucks you get the special stainless tee, the adjustable dump valve and the necessary fittings. The only thing you need to purchase is some 3/4" heater hose and a through transom water dump. It works great. Let me know if interested.
Craig
Craig
speel chekk this fokker!
if it will work i will take it!
I snap apic of my engine so you can see mysetup and you guys can let me know if it will work.
Pardon me, while I whip this out!
Had have crossovers had way to much water pressure engine
guy installed a restritor made by moroso they have different
size to get the pressure you need. Work great no problems since
Pudder I was looking at the stainless book and I think that mine will not work on your setup. It is called the( big block kit with bypass port entry).They offer quite a few kit's so if you call Stainless they could tell you if it would work.(305)681-7893
Puder I got mine from CP Performance and have run them for 3 seasons. I have the thermostat. Temp is a perfect 150 deg and never moves. 18# pressure at WOT. The work excelent and I was even able to use the factory outlet hoses. I did fabricate a solid hose going from the cooler to the bypass out of copper plumbing pipes and fittings and painted it black. Works great but I am in fresh water.
