Water pressure; Looking for the real answer! >
Old 07-07-2003, 06:00 PM
  #31
MIKEHTMSR24's Avatar
Post 3
MIKEHTMSR24 is offline
Old 07-08-2003, 11:59 AM
  #32
32' SUNSATION
Kanookstr's Avatar
My procharged 502 runs at around 5 lbs Idle, and It can run at any pressure I set it for WOT. But I'm set at 24 psi.
I put my pressure relief in the procharger cross over.
My intercooler is fed by the outdrive when under way.(Thats why theres a red X on the picture). I have a 1 1/4" thru hull feeding the engine via sea strainer. My Stat housing dumps over board, Don't need the extra water steeling any HP. I run a 120° stat with 1/16" hole, because I boat in the N. East and engine water temps never see above 90° without a stat. I have been running this set up for 280+ procharged hrs. 40 of them this year.
Attached Thumbnails Water pressure; Looking for the real answer!-crossover.jpg
Kanookstr is offline
Old 07-12-2003, 07:18 AM
  #33
offshor
Default Merc Water Relief Valve Pictures
Look in the general discussion thread. I posted a picture and sketch.
Old 07-12-2003, 07:55 AM
  #34
32' SUNSATION
Kanookstr's Avatar
offshor, can you post the link to that thread??? Mine is set up like this except for the intercooler goes to a billet drive shower cap.
Also you don't have to relocate your oil cooler, Mine is there because I had to relocate for the super charger. The stock location is fine.
Attached Thumbnails Water pressure; Looking for the real answer!-waterflow2.jpg
Old 07-13-2003, 07:43 AM
  #35
offshor
Default Post
It's on page 2 now of the "general discussion" section.
"merc water pressure releif valve picture "
Old 07-14-2003, 08:12 PM
  #36
32' SUNSATION
Kanookstr's Avatar
Whats the name of the thread offshor??
Old 07-15-2003, 01:55 PM
  #37
offshor
Default Merc
" merc water pressure releif valve picture "
Old 07-15-2003, 07:04 PM
  #38
mleslie951's Avatar
Default Water Pressure
Wette Vette's deal works.......
I had two motors over 40 psi on water pressure. The system is fully adjustable for each motor. I comfortably run under 22 psi WOT.
Mike
Apache 28
mleslie951 is offline
Old 07-15-2003, 08:51 PM
  #39
32' SUNSATION
Kanookstr's Avatar
Sorry Offshor, but a search using
brings you back here.....Thats a search in all forums...
Old 07-15-2003, 11:47 PM
  #40
Ginger or Mary Ann?
US1 Fountain's Avatar
Here ya go...........Merc relief valves
US1 Fountain is offline
Quick Reply: Water pressure; Looking for the real answer!
