Best aluminum head?
Take a look at Brodix's newer BB-3 Xtra O 332cc CNC head:
http://www.brodix.com/heads/big-bloc...a-o-exhaust-2/
Then click on "Flow Chart."
That's got a marine 540+cid all over it !
exactly!!
I think they all flow about the same AFR, Dart, Brodix depending on runner and valve size, I think it boils down to preference and budget
Edit: buy them bare and have an experienced builder put them together to match the cam and other valve train components, jmo
Edit: there's a few threads about this
I like my AFR, and price was good, just wish I bought them bare because I still ended up setting them up custom for my application, so it defeats the "bolt on and go" price....
and don't try to save a buck here..... buy bare and have them built.... trust me, don't let "HOW MUCH" hurt ya lol
Aluminum don't make the heads better really, it's the flow...
A buddy built 502's with 265 edelbrocks ported, 9.5:1 not sure cam at moment but I think 232/[email protected] .640 lift on 114 , dual plane intake and worked 750 carbs, made 621 hp and 640tq
Funny how good those 502's with those "too small" dale cubic built 750 holleys run.
![Wink](/forums/images/smilies/wink.gif)
The cams are from bob and the engine was only spun to around 6250 on the dyno. Carb was super close right from dale with only a bit more fuel needed in the mid range.
A dyno pull isnt the end all to a carbs tune.
Btw, is your boat running yet ? Did your engine builder finish that supercat build ? Or are you still sitting in your den dreaming about boating and throwing cheap shots at me?
