problem with aftermarket cylinder heads.
#151
Anyone check the closed/open pressures on the springs that come with AFR heads for a hydraulic roller setup? With the blue stripe on them. I think they are made/sold by Pioneer? Curious what they come with spring wise
#152
They no longer use the pioneer spring, stopped using the pioneer spring over a year ago. Mine came with Pac springs
#153
Just looked thru the AFR 2015 catalog, only seeing #8002 blue stripe spring for hydraulic roller. Its listed as a chrome silicon material spring.
http://www.jegs.com/i/AFR-Airflow-Re.../8002/10002/-1
#154
I only know this information cause I dug into it when my builder was checking over the heads and thought the stripe on my springs was blue which is the pioneer spring, and said if they are the pioneer spring we would have to change them. I spoke to AFR directly after talking to Bob and both assured me they were the pac springs, so I went a step further and sent AFR a pic of my spring for clarification and had then send me a pic of the blue stripe spring so I could see for myself. Jerami from AFR said they cleared all inventory of the pioneer spring by September of 2014. the thing is the blue and green stripe are not a clear blue and green like they probably should be
Pic of the green stripe Pac Spring that my builder took
Pic of blue stripe pioneer spring
#155
Only reason I am asking, is a buddy is looking into some AFR heads, and trying to weigh the cost of buying assembled, vs bare. He wants a true endurance spring in them. AFR isn't very clear about the actual springs they are supplying, or who they are made by, what part number, etc. They just give you their part number, which doesnt tell you much. Dart at least provides that info, manufacturer of supplied springs, and part number, which you can then research on your own.
#156
Ealesh, safe to say this info is incorrect , or outdated here? Not seeing a "pac" spring available for the bbc hyd roller application? They still showing the pioneer, with their #8002 .
http://www.airflowresearch.com/valve_spec.php
#157
they do on their site, but their site is also not accurate, Jerami told me this when we spoke, cause I asked why the pioneer spring was still listed on there if they did carry it anymore, and he said the need to update it, well I just looked and it is still there lol. Also they have changed around their stripe colors on springs. Like they had pioneer springs also marked with black stripes which they don't anymore and the green stripe isn't a hydraulic roller anymore. I assume they did this for QC as the green and blue is kinda close in color, but that's just a guess. There was also contradicting info on different spots of their site which also contributed to my builders concern. He said the pac is a good spring, but the pioneers were basically junk, and if that's what they were we were going to swap them for the isky tool room springs. Here is the email he sent me confirming the pic i sent them was in fact the green strip pac springs.
#158
Honestly I would get in touch with AFR and have someone directly address any concerns you may have.
#159
Thanks for the info .
#160
Fu$% AFR! They`ll send you some $hit box with solid roller springs set up or some pioneer cheap springs with a hand job tight valve guide.
If I were to buy a head for a BBC it be anything but Air Fart Flow.
Hearing great things about BBC Trick Flow heads.
