How many hours on bigger power stuff?
#71
Geronimo36
I've always been hesitant to run a meth injection for fear that the customer will let it run out, not realize it's not on, etc. etc. and burn the engine down. If it was my own, then no problem. I have some customers that can't check the oil correctly, so I try to make everything as simple as possible. For lack of a better term, I have to make it dummy proof. lol
However, meth injection is a very viable way to get the job done. As well as cooling the intake charge, it has the added advantage over an intercooler by raising the octane a bit. It definitely works when set up properly.
Sounds like you are getting it dialed in. Good luck with it.
Eddie
Eddie
Running methanol through a fuel system is one thing of flushing system to prevent corrosion after the fact, injecting methanol into the intake charge has a cooling effect of the air charge... I guess the question is are you changing the the A/F ratio to correct for fuel and addition of methanol at those points excessive methanol creates moisture within the air charge due to the absorption of moisture, this will cause milking of oil and contamination of oil from UN-burnt methanol....If all these factors are addressed, it's a great power multiplier.
A friend of mine is running E85 and meth injection on his 1800hp drag car without intercoolers and it's working unbelievably well. He's been helping me get mine dialed in and we've been talking a lot about what mixtures to run since most of the meth evaporates out of the charge once it travels through the blower.
It's been a fun journey so far.
#72
I don't blame you. I don't think I would send one out the door with it either. It's definitely something I keep an eye one but couldn't expect the average Joe to do that. I'm running two 1 gallon tanks and they both lasted the whole summer. Although, my WOT passes were very minimal.
I'm still dialing everything in. Originally my goal was to tune the engine and then have the methanol as backup but I quickly learned that you need to tune it for both. I've also found that my A/F numbers are actually lower "without" the meth and higher by 2 tenths when the meth is on. THe cooling affect and the meth are leaning it out just a little bit. Right now the setup is very rich and I'll be pulling some jet out of it in the spring. The system is set to come on at 4psi and it progressively increases up to max boost. Haven't noticed any milking of the oil what so ever.
#73
Geronimo36
Its supposed to drop the intake charge by 150 degrees. I don't have a probe to test it and probably wont bother at this point because I recorded a 1 mph increase on Meth and slight increase in RPM. The bottom line for me is that it's doing its job.
#75
Im just curious. We monitored intake temps on icdedppls 10-71 blown 540 with 7-8lbs of boost. No intercooler. Temps were 140-150 in the intake at wot. If meth dropped it 150 deg, then that would mean the intake charge would be 0 deg F! It would be nice to see ambient temps in the manifold though
#76
#77
Geronimo36
My guess would be that an engine would require an incrementally lower A/F ratio with a higher percentage of Alcohol in the gasoline to be safe. The methanol injection is adding more fuel and cooling the air but it's also providing a more complete burn. I don't know what affects water has on all of this equation. The theory makes sense to me but I'm not an engineer, nor am I an expert in the area. It's all new to me but it seems to be working so I'm rolling with it.
#78
LOTS of guys running meth tanks on turbo snowmobiles at the 350 to 500 hp level, yes, guys are getting 450+ hp from 1.1 liter sleds, a few have blown up though at high boost levels when meth ran out or pump malfunctioned, fwiw, Smitty
#79
Mark brought up a great point about AFR's. Straight Methanol has an ideal AFR of something like 7 or 8:1 (I don't know for sure, but I know it's much lower than gas) When you start adding Meth, should the AFR's be brought down. If an engine does it's best at 12.5:1 on straight gas, then what would it be with some Meth mixed in? I guess that would be determined by the amount added, but is it proportional? If you added 10% by volume to the gas, then would the ideal AFR drop by .45 to 12.05:1 (10% the difference between 12.5:1 and 8:1)? I don't know the answer to that. Who does?
Eddie
#80
we have been running a drag car turbo LS power 25psi on E85 no intercooler w/meth as well and works great, I tried the same setup on our procharged 509 and even with the smallest jet they said they had slowed the boat down everytime the meth came on...now that was at only 5-6 psi
