Looking for best Bilge Paint. Can you recommend? >
Old 11-16-2015, 09:08 PM
Gel coat with Duratec additive. No cheezy implement paint.
JRider is offline
Old 11-16-2015, 10:44 PM
Looks like I started a monster ....
Also used this and the rustolium for years. Hold up extremely well. Just mix in the recommended amount with your paint and let sit for a half hour before use. Dries hard as a rock in a hour.
http://www.amazon.com/Valspar-4625-E.../dp/B000LNY1MY
f_inscreenname is offline
Old 11-16-2015, 11:07 PM
Whatever Glassdave recommends is what I would use.
BenPerfected is offline
Old 11-17-2015, 05:31 AM
Tile-clad from Sherwin wiliams. It's a two part epoxy that is tough as nails and sticks to anything. Definitely more expensive than rustoleum though.
wfo1 is offline
Old 11-17-2015, 06:26 AM
Originally Posted by cyrus77
I put new stringers in the boat. I with epoxy. I like the idea of sealing it with more epoxy paint. I just do not want to experiment with Rustoleum if it is not a sure bet.
You shouldn't be using paint as a sealer. That's what the fiberglass resin is supposed to do. Epoxy paint will chip, crack, and flake over time. If you think that it's going to seal water, I would think again.
x100 on the rust oleum that's what we used.
1MOSES1 is offline
Old 11-17-2015, 07:51 AM
carter38's Avatar
Awlgrip
carter38 is offline
Old 11-17-2015, 08:00 AM
150bucks for 2 gallons sherwin Williams epoxy. Probably take less than half that for your bilge and it covers so well I am sure you only need one coat.
The fumes from doing a bilge in Imron without a pressurized fresh air resprorator is a deadly mix.
tommymonza is offline
Old 11-17-2015, 08:04 AM
Ignore this post...Gel coat is a big NO NO over epoxy. I used Sherwin Williams Macro Poxy to coat my Profile bilge, that stuff is thick, sticks to anything, and tough as hell.
JRider is offline
Old 11-17-2015, 08:18 AM
Can't beat the rustoleum used it several times works like a champ and hard as nails !
ezstriper is offline
Old 11-17-2015, 06:08 PM
Received 4,974 Likes on 1,403 Posts
Another vote for Rustoleum , stuff holds up great, good price too.
ICDEDPPL is offline
