Rods
#81
I wonder if that had any influence on the old 427T tall deck truck engines design concept. Using a short stroke , long rod combination. I know they had the 4 piston ring deal, but wonder if they knew those engines were going to need to last in heavy duty commercial trucks, with short gears, and not wear things out
#82
I remember those things in a lot of older dump trucks, those old bombers that would be screaming at like 4k rpm to do 55mph ...lot of revolutions per mile on those things
#83
Had the pieces at my shop for one and used the blow through carb and intercooler on one of my small blocks it was cool.
#85
manufactured for me Mike... same as Howards and a few others are doing... they're great rods and reasonably priced... I'm running them in my own engines as well as several other builds out in service...
#87
i d[d not know that.can you say who is making them?
#88
I will say this... they are great quality, priced right and the finish machining is done here in Toronto... as I said earlier, we've been using these for many years... seeing that I'm not the only guy doing this, I respectfully decline to name drop the front end supplier...
#90
can you post a pic showing the cap&bolts?
