TBS 871 to BDS 1471 questions?
Mike not sure your age. But to you remember when you could get Torco fuel at the pump? the good old days now you have to by it in a 55 gal drum, we where pushing 12 psi of boost with 871's on 540cu blocks back it 2002. when you dropped 1k in fuel at the pump and was gone before the end of the day.
BTW, I pretty much scrapped this blower swap idea. I think the money would be better spent on props. Right now my props put me at a cruise speed of 100 at 4400rpm...I would like to get that cruise rpm down some. A 5k for a set of used #6 5 blades gets a little salty...
Just needs siding, and the big door! will be done in the spring not one for freezing my @@@ off outside trying to finish it. LOL agree with the prop statement, also need to run the hell out of it then figure out where to drop the extra $$$ into it. Get my text about Flex at boyne?
o
Mike, I also am an old poop. I remember in the late 60's into the early 70's it was cool to pull in and dial your own. It must have been a logistical nightmare to have about 6 or 8 grades available to blend at the pump. Looking back,maybe the Sunoco guys were just blowing smoke!
I remember at the Phillips 66 premium ( Ethel ) was a dark red color, man what a smell. Make you lawn tractor haul A$$
