Off the shelf cam options for marine engines >
Old 02-15-2016, 05:18 AM
  #141
Originally Posted by MILD THUNDER
Did it at least the power you were looking for ? That couldnt have been a cheap ordeal .
I picked up a new block the day before Christmass. Unfortunately the block still hasn't been machined.
The 55mm cam was $550. Which doesn't bother me at all. It's the $4200 on the AFR heads that I could shoot myself for buying. I personally never really cared for there heads. I think they are around 25-30 hp less than some other heads out there. I think they are a good casting but Brodix has it all over them in that department and Brodix offers a anti-corrosion coating that they warranty for 7 years. And I can tell you a whole summer of 900hp through a set of exhaust ports and the coating looks untouched.
Black Baja is offline
Old 02-15-2016, 05:42 AM
  #142
Originally Posted by Full Force
Boost makes everything run good lol
My buddys 353 has Merc 525 roller cams, easy on valvetrain makes about 850hp with 7 lb Procharger...
How fasts that boat?
sutphen 30 is offline
Old 02-15-2016, 07:56 AM
  #143
Originally Posted by HaxbySpeed
Thanks Scott, and thank you for contributing tech in TECH forums as well. I owe Chris Straub and you an apology for interactions we have had in the past on here. I was given misinformation about both of you that caused me to form an unfair opinion. Hopefully this place can get back to being about engines, and the free sharing of information. Cheers
Alex thank you for accepting my call and the conversation sir. I look forward to working with you in the future on some projects sir.
StraubTech is offline
Old 02-15-2016, 07:57 AM
  #144
It was good meeting you also and thank you for the kind words.
Old 02-15-2016, 08:14 AM
  #145
Originally Posted by mike tkach
this thread has been a good one with a lot of good information.lets not fuk it up and get it locked or removed.also,imo if you have 16 lifters in a engine and one fails[colapse]soon after startup i think the problem is that lifter,not the cam lobe.i had this happen on 3 different engines on the dyno,twice with 5w30 oil.all 3 had different cams.bck,throw all 16 of your old lifters in the trash.they can only cause you problems that you don,t need.jmo.
An old engine builder once told me, Chris if you take the L and F in lifter and switch them you have FiLter. One reason the Morels are able to sustain power at higher rpm is because of tolerance. The tolerance held is .00003" in the Morel valving. We moaned and groaned about the hyd rollers not being able to rpm....if you read the net their are plenty of forums that will say this.....Morel will go 7000 rpm plus, but they must have a clean enviroment. Nature of the beast.
Our return rate on 4603 morels for inspection was a total of 4 sets last year. That represents .011% of the sales of that part number returned. When PAC racing springs wanted to sell lifter for LS engines. They bought a set from every mfg. All of the lifters went through extensive testing. PAC only puts Morel in their catalog. The LS, the BBC, the SBC all use the same body from Morel. The only difference is the tie bar. If I put all the returns of these 3 lifters together I am at .007% in returns for the year of 2015.
There is no wide spread issue with Morel. There is an issue that Morel does not have that many direct accounts and is not adding any BECAUSE they can not keep supplied the accounts that they do have currently.
Old 02-15-2016, 08:23 AM
  #146
With any engine build there are compromises, even more so with a marine engine. Budget, octane, sustainable rpm, maintenance intervals, wet exhaust, idle rpm and quality, etc. Given these are constants for most end users, and the basic architecture of the BBC, there isn't a lot of latitude when choosing valve events. If you look at cams that have proven to work well in this environment, you'll notice a trend. The cams that I have had failures with, and not all of them had issues, have ranged in size and application. Even mild custom cams with low lift have caused lifter tie bars to break off from wacky harmonics. This is most likely not a result of the actual valve events, but the overall shape of the lobe. There is some pretty serious math involved in designing a stable lobe. Duration in cams for these marine applications is fairly consistent, and its easy to get close to your target rpm based on the cubes, and quality of the cylinder heads. The biggest gains in power in the last seven or eight years has come from cylinder head design, not cams. When you try to add a bunch of lift to take advantage of potential airflow in these killer heads, but need the smaller duration to stay in your rpm window, it can be very hard on parts, can ultimately make less power do to instability, and will be difficult to tune..
Alex I will add in this type of application one must build a combination that can take 8K#s from 800 rpm to 6000 rpm without the assistance of gear changes. One must build for the widest most usable power within the rpm range and concentrate on torque and not peak HP numbers that in most cases the boat engine will never see.
To do the above one must use cylinder head cross sectional area best suited for maximum performance in the mid range. Large heads make HP, they do not make torque nor due the tend to make wide flat powerbands. The industry if very guilty of marketing "Bigger is Better". This naturally feeds the male ego, but in reality can lead to disappointment in the end.
I think it is key to build for average power.
Old 02-15-2016, 08:32 AM
  #147
Whats your guys thoughts on valvetrain noise ?
Ever notice one cam can have a very quiet valvetrain, and another can be quite noisy, with the same lifter ? Why would that be ?
OEM type cams are designed designed for .700" wheel lifters. These lobes are non aggressive and very easy on valvetrain because attached with OEM is going to be a warranty. I would venture to say 90% of all aftermarket stuff is designed for .750" wheel and SBC core size. Once you take a lobe designed for a given base and transfer it to another core size, well now where we can run into some stability issues. Velocity rates change on the flank and one can run into harmonics very quickly.
MASS, a hyd roller is heavy. We went to recommending 7/16" pushrods for most BBC builds with hyd rollers with lobe lift .365" and greater when using the Morel 4603 lifter. On SBC and LS engines we recommend 3/8" stuff.
Rockers arms can be an issue also. I work with ATK's Performance division and they have found changing rocker mfg can get rid of a lot of valvetrain noise in some cases.
Old 02-15-2016, 08:41 AM
  #148
If a shelf master is use there is no up charge and there is normal turn around time. To have a completely new master generated runs from $100 to $200 per profile. So a cam with a new intake and exhaust would cost you $200 to $400 for engineering the the cost of camshaft. This would run around $800 to $1000 per camshaft for a BBC.
Old 02-15-2016, 08:42 AM
  #149
I have a very similar build. My motor started as a 502 Mag. Had it rebuilt by Champion Performance last year. Now it is a 509 7 lbs. Boost Procharger with 525 cam. I remember when the builder recommended the cam. In the back of my mind I was thinking why not a custom cam? I went with the Builders recommendation as he obviously knows a lot more than me about motors. Glad I did.
hadleycat is offline
Old 02-15-2016, 08:44 AM
  #150
Full Force's Avatar
Best of 107@6000 rpm 36 4 blades
Full Force is offline
