Off the shelf cam options for marine engines
#631
I have used them in the past and they worked fine. I did not compare them to anything else at the time since I had no problems with them. I will try some other carb's on it to see if I get more out of the engines when I run the boat. That will be better than a dyno test for a horsepower comparison.
#632
906 Chrysler heads
This is a numbers matching engine for a 39,000 original miles car, so the idea was to keep it simple, cost effective and reliable. It's an ice cream cone getter.
#633
i don,t think it will make 450.what was the factory hp rating?
#634
Tim, at 5500RPM in the boat, at 5500RPM on the dyno, your engines and Alex's engine, are very similar in power output. In my opinion, what you need, isn't more "torque" if you want the boat to go faster. What you need, is a combo that produces more upper RPM power. Unless I am missing something, how would Alex's combo there, make your boat have a higher top speed considering your current combo is hitting a wall at 5400-5500 in the boat?
With that being said, its pretty sad that Alex's combo here, is making similar peak power, and more low end power, than your 325 AFR CNC chambered combo, with Chevy Iron castings! Between 5400 and 5800, you picked up 11 horsepower. I know your goal was a 6000RPM 700HP combo. Something was giving up short. I doubt it was the 325 AFR heads, I doubt it was the 1050cfm 4150 carb.
#635
Just figure the TQ would carry the heavy hull easier, like my old engines, that 30ftlbs each missing I can feel, the boat was more "zippy" before...
needs boost lol
[QUOTE=MILD THUNDER;4408180]Tim, at 5500RPM in the boat, at 5500RPM on the dyno, your engines and Alex's engine, are very similar in power output. In my opinion, what you need, isn't more "torque" if you want the boat to go faster. What you need, is a combo that produces more upper RPM power. Unless I am missing something, how would Alex's combo there, make your boat have a higher top speed considering your current combo is hitting a wall at 5400
needs boost lol
#636
Geronimo36
It's definitely much more uneventful firing a roller cam engine you just built compared to a tappet engine, that's for sure!
#637
I used to think so too. Until of course, I've seen hydraulic roller lifters collapse at start up. Sucks when it happens on the dyno, and you have to pull off the blower, intercooler, intake, distributor, and so on to replace the lifter. Of course still not as bad as a flat tappet going flat, but still a pain in the azz.
#638
#639
Almost the end of page 64 and we are now on flat tappets. Did we go so far we hit a time warp of 12-15 yrs ?
#640
Geronimo36
I also prime the engines now without the pushrods installed until the lifters are fully pumped up and there's no air in the system.
