Off the shelf cam options for marine engines
#641
Geronimo36
#642
365, but we all know those "ratings" from the big three in that era were all over the map.
Really, it's not a race car. I just can't leave anything alone so I started foolng with it and wound up with ported intake, heads and a solid cam.
It was good to go through it as we found a few suspect assembly things we fixed. (Junky//bend oil pump pickup, distributor bushing in the block spun, # 2 cam bearing was gone)
#643
I have a nice engine package for the big block chryslers.will see if I can find the paperwork.also did a nice stroker sb chry for my brothers AAR cuda.
#645
Speaking of this, how high do port velocities get? A 2x2 inch port that flows 400cfm would have a velocity of 240 ft/sec. What if with a blower you sped this up to break the sound barrier? Would the engine just sonic "BOOM"?
#646
Ports never go past the speed of sound. But that is variable based on localized density and temperature..
#647
Geronimo36
#648
Not if you lined the ports with sound deadener.
#649
The port velocity won't break the sound barrier.
#650
