Supercharged v NA
#101
So to really confuse the matter. Why the resistance to turbo charging .
Back n the day Brownie talks of all the old turbo charged Daytona motors and what a hot package they were.
Than Mercruiser came out with the 454 daul turbo motor that made 475 horse with its tiny non water jacketed housings.
I ran little 300 horse turbo Yanmar diesels that had no lag what so ever . So what is the hold up with turbos?
that would boost the power to 775 HP. It had a starting price of $12K, but it seems like the project stalled. http://speedonthewater.com/in-the-ne...-in-miami.html
#104
I'm guessing for $12K you can buy a blower for much cheaper and be able to bolt it on in a weekend with minimal amount of fabrication and achieve similar power levels
#105
this is correct but both roots and screw blowers do the same thing,pack air into the cylinders.the screw blower just does it more efficiently.on another note,nitrous oxide does the the same thing in a different way,it puts oxygen in the cylinder.
#106
Anyway, my 565cid NA's made something like 660-670 lbs of torque....and I still believe my friend's boat should have kicked my arss from the torque alone with those Superchargers---especially from 3500rpm up. I surely thought he would have pulled away from me as we both climbed to 5600rpm, but he couldn't do it---we tried several times on different days.
Bill, you could be right about the power of his engines not truly making 750hp, again, maybe only 700hp, I really don't know, but I still think he should have whipped me from the midrange 3500rpm on up with those superchargers.
#107
Mild, that chart has quite an intake temp... 241*? Wow, is that with a barbecue grill cooking some hot dogs on a 100* day above the intake?
#108
That 16/71 was not a high helix was it?
#109
no.
#110
I was thinking it but you said it! LOL
