Supercharged v NA >
Supercharged v NA
Supercharged v NA
Old 03-06-2016, 10:30 PM
  #81
Received 4,993 Likes on 1,408 Posts
Originally Posted by horsepower1
Probably closer to 150
So I have 1050hp motors and after the blower eats 150 , I make 900?? I don`t believe that.
Mike, same heads, same boost?? Compressing air creates heat, Whipples still make heat .
ICDEDPPL is offline
bb1 (10-05-2022)
Old 03-06-2016, 10:36 PM
  #82
I don't see that being unreasonable . Let's spin one of your huge commercial A/C compressors to 5000 and see how many Horsepower that takes.
tommymonza is offline
  #83
nothing changed on the engine,just the supercharger.yes when you compress air you create heat just not as much with the screw blower.not the same boost,you can safely make more boost with the whipple.
mike tkach is offline
Old 03-06-2016, 10:40 PM
  #84
Whipple sound like a greats Value ? Less heat so not the need for a inter cooler if not desired and over all more efficient . So what is the downside?
CFM to CFM what does a Roots go for compared to a Whipple?
Old 03-06-2016, 10:44 PM
  #85
dan,i would say 150 is probibally pretty close.another way to look at it is you have a 750 hp engine that makes 900 with the blower.i will bet you pick up 30 to 50 hp from the compression increase and the ring seal&valve seal.
Old 03-06-2016, 10:47 PM
  #86
SB
Received 3,329 Likes on 1,491 Posts
Cost...by a ton.
SB is offline
Old 03-06-2016, 10:57 PM
  #87
the inner cooler lets you run a little more boost.if you keep the boost at a safe level and have the correct tune up you don,t need an inner cooler.dan made 900 without an inner cooler with iron heads.we are upping his compression ratio so if we leave the boost the same he will make more power.i can,t say but i think he will turn the boost down and stay around 900 hp.
Old 03-06-2016, 11:14 PM
  #88
Originally Posted by SB
Cost...by a ton.
Now we are in Iceededppls realm . Lol
Old 03-06-2016, 11:16 PM
  #89
Long as we are on this subject , what are you losing for horsepower or intake flow with a inter cooler ?
Old 03-06-2016, 11:31 PM
  #90
imo,nothing,you just turn the blower a little faster to make up for the restriction.it really is not much.if you were to add a boost gauge above the inner cooler i am guessing 1 to 2 lbs more than in the manifold.remember,boost,or pressure is created from resistance to flow.
