E85 With Flex Fuel Sensor Who Is Running It?
14 apache, don't you really need the higher compression ratio when running alcohol to compensate for the loss in fuel energy? I understand there is advantage when running modified engines for drag racing etc, but I just meant being available at the pump for a daily driver.
been racing/running E85 for years now, in a low compression, non boosted deal, no reason to use it in my opinion, now with high compression 12-1+ or boosted the stuff is great. I run 25psi+ in a LS engine no IC @1200hp right out of the pump, but yes you will burn about 40% more.
