FiTECH Fuel Injection Systems
#41
if they are putting the MAP in the throttle body and not making a means to change the vac sensing to the intake would be idiotic to me, understand making it simple but...
#42
I just ordered the 1200hp power adder system and command center for my blow-through set up. It shows a one month back order so I'll keep you all posted on results.
#43
http://fitechefi.com/virtualoffice_f...%2012.9.15.pdf
ezstriper, Page 4 of the manual shows how to change vac sensing. (figure 4 and 6)
#44
Hahaha! Friggin' awesome! Going to email the tech now and see if that will work for spark management on draw thru!
#45
The way I read it, it seems the boost retard feature is a function of RPM and not actual boost (guessing). I would think you would need more than a 3x3 matrix?
"SPARK MAP: The spark advance uses a 3x3 matrix table to allow flexible spark advance control. This
can allow distributor simulation, locked timing, boost retards, high RPM advancing and other
strategies to optimize the ignition spark advance angle"
Page 3 of this manual - http://www.fitechefi.com/virtualoffi...efinitions.pdf
PS.. they also told me i needed a boost retard module like MSD makes, so something doesn't add up here.
#46
#47
#48
Got an answer from Fitech!!! Good catch Jackhammer!!! Here's what the tech said:
Hi Charles
you're absolutely right, I so apologize, I totally forgot all about that. You will have timing control the ECU will read boost, all will be right with the world.
Embarassed Thank you so much for straightening me outEmbarassed
most the time and pretty good this job.
Anything else let me know
Thank's
Kirk Spiger
Tech Support
FiTech Fuel Injection
Hi Charles
Thank's
Kirk Spiger
Tech Support
#50
Well... I got an email that the systems are on back order until July 14th at the soonest. I just cancelled the order as many new products and versions are hitting the market soon so it's worth it to me to wait and see. In the meantime I ordered a wideband to play with on my QF carb.
