some 4150/4500 dyno info >
Old 05-15-2016, 08:21 PM
SB
Received 3,217 Likes on 1,455 Posts
Originally Posted by bck
Here is the quote from the Teague tech article that had me interested.
"Try the World Products Merlin X to accommodate a Holley 4500 series Dominator carburetor. The manifold works well out of the box and has brass inserts in the water passages to protect from corrosion. Select a two-circuit 1050 CFM carburetor. Three-circuit carburetors run rich in the midrange. Under the carburetor, install two 1-inch spacers. The top spacer should be a four-hole design, which lengthens the carburetor venturi and improves the booster signal.
This improved influence on the carburetor boosters will improve throttle response with the big carburetor. The spacer next to the intake manifold should be a cloverleaf design that improves the flow transition from the fourhole spacer to the intake manifold plenum..."
Yes, but on his 650 and up NA Dom powered engines he ran 2" HVH Super Sucker spacers.
SB is offline
Old 05-15-2016, 08:29 PM
bck
Charter Member#568
bck's Avatar
Well, I've tried the 2 inch HVH then. This is a Dom package he's referring to in the above.
Straight bottoms and flat decks
bck is offline
Old 05-15-2016, 10:19 PM
Received 1,494 Likes on 808 Posts
Originally Posted by Black Baja
The purpose of a 4 hole spacer is to protect the booster from the pulse that travels back up the intake port when the intake valve closes. If that pulse slams the booster you are in trouble. Fuel turns into a puddle in the bottom of the intake power goes down and detonation goes up. You really need a properly designed spacer to get the job done correctly. The HVH spacer looks cool but doesn't protect the booster.
Tried sending u a pm but your full
John
getrdunn is offline
Old 05-15-2016, 10:47 PM
What was the compression ratio and general cam spec's on your engine? Nice post by the way, lots of great info!
endeavour32 is offline
Old 05-16-2016, 01:27 PM
bck
Charter Member#568
bck's Avatar
We were supposed to do a head to head comparison of 9.3 vs 9.7-8 but issues beyond our control prevented that. I should have that info when we're done but won't be able to use it for decision making. The first group of pulls with the 4150 intake were 9.7. The second group of pulls with the 4500 intake are 9.3. Cam is roughly 243/654.
bck is offline
Old 05-16-2016, 01:53 PM
Just an FYI the Pro Comp spacer on the same motor/ same dyno/ same day made the same power as the HVH spacer.
Black Baja is offline
Old 05-16-2016, 02:24 PM
SB
Yes, and it probably came with a free piece of a ham sandwich, if you ground it out.
SB is offline
Old 05-16-2016, 02:44 PM
That costs xtra...
Old 05-16-2016, 03:24 PM
You think your getting a VIP invite to cam room. Some go to their grave with those secrets. Ha... Don't worry I didn't get the magic numbers either. Needless to say it is a great thread with good info regardless. All I can say is going to dyno room with a truck full of goodies to try is a riot.
getrdunn is offline
Old 05-16-2016, 03:44 PM
bck
Charter Member#568
bck's Avatar
I gave the general specs he asked for. It's a shame we didn't get to do the head to head comparo on the half point of comp. But we had some obstacles crop up that prevented it.
bck is offline
