clear (dry or glazed) plug fouling??? Stumped....
I'll put down $5 that it's the ignition. Generally speaking, electronics can work fine until strong continuous current warms them up exposing a fault, and MSD hasn't had the best track record here.
I'd open the hatch and wait the amt of time it takes you to replace the plugs. No shorter. And then try to restart and run.
I can certainly try this. May try putting the plugs back in one engine just for the hell of it and see what happens.
Did the carbs get rebuilt lately? I did a dominator once put the wrong gasket in and when I shut it off it would siphon the carb dry. changed igniting on it drove me crazy.
Thanks for the input!
Ignitions have common power source and ground? There may be something going on there. The po of my boat ran a 20g wire to the coil when it required a 12g and it was at idle that noticed a significant difference.
Have you tried changing out the brand of beer that you consume when yelling at it? I've found that to be as effective as anything else troubleshooting boat problems.
