Jesel Belt Drive, Crank turns Cam and Belt Stationary
I'd be more concerned why it stripped the teeth off. Have you pulled the plugs? Do a comp/leak down test? You said you took a wave up the back..any chance it stripped the belt due to a hydrolocked cylinder?
BTW, I cut the belt off and it almost looks tore. So I have some definite concerns about my valve train. I was able to turn the cam but not easy...although I do no know how hard it is to turn one by hand. Looks like i have to pull the header to get the valve cover off, or atleast loosen it.
If there is enough resistance anywhere in the valve train then the weakest link will give which would be the belt. I'd pull the valve covers and loosen the rockers to shut all the valves and put air in the spark plug hole on each before I went through and retimed it with a new belt. You will hear a hurt valve either through the intake or exhaust.
It is a little tough to do a compression and leak down with the cam not turning. I did wonder about the hydrolock that is why i mentioned it, but motor did not hesitate to turn over and it (hydrolock) would stop a piston from going up but how would it stop a valve from opening?
