Jesel Belt Drive, Crank turns Cam and Belt Stationary >
Old 06-13-2016, 10:34 AM
  #31
Originally Posted by Baja Rooster
Seems like a good plan there. Pull the plugs and if possible spin it by hand at the crank.
Not that it matters, but what are the odds of the belt just breaking and the wave was a coincidence?
Tensioner could have been loose.
JRider is offline
Old 06-13-2016, 01:22 PM
  #32
Knot 4 Me's Avatar
Originally Posted by JRider
It is a little tough to do a compression and leak down with the cam not turning. I did wonder about the hydrolock that is why i mentioned it, but motor did not hesitate to turn over and it (hydrolock) would stop a piston from going up but how would it stop a valve from opening?
BTW, I cut the belt off and it almost looks tore. So I have some definite concerns about my valve train. I was able to turn the cam but not easy...although I do no know how hard it is to turn one by hand. Looks like i have to pull the header to get the valve cover off, or atleast loosen it.
You can take water in an engine, do this, and the engine start up and run (albeit with a heck of a knock).
Attached Thumbnails Jesel Belt Drive, Crank turns Cam and Belt Stationary-bent-rod.jpg   Jesel Belt Drive, Crank turns Cam and Belt Stationary-piston-damage.jpg
Knot 4 Me is offline
Old 06-13-2016, 01:36 PM
  #33
SB
Received 3,277 Likes on 1,467 Posts
I've pulled apart a few decent running engines with no noises that had bent rods. Doh !
SB is offline
Old 06-13-2016, 07:09 PM
  #34
Ok, rotated the cam and the crank incrementally and heard a valve slam shut. Bore scoped it and there is valve contact with piston, at this point I see no other option but to have the motor pulled and go through the heads.
JRider is offline
Old 06-13-2016, 07:14 PM
  #35
That blows.
Crude Intentions is offline
Old 06-13-2016, 07:28 PM
  #36
Hopefully it's just a couple valves. The guides may be bad too, you probably know that.
Mr Maine is offline
Old 06-13-2016, 08:23 PM
  #37
damn,that sucks.hope you get the heads back quick.
sutphen 30 is offline
Old 06-13-2016, 08:43 PM
  #38
Double check all of the piston heights if there is any possibility of water in the cylinders. I have see people skimp on that and then break a rod the next time out with fresh heads.
indysupra is offline
Old 06-13-2016, 09:17 PM
  #39
Originally Posted by I.C.U.Lookin
That blows.
Understatement of the year, 2 weeks to get this ***** back together for the 4th and then Boyne!
JRider is offline
Old 06-14-2016, 02:24 PM
  #40
That blows. Best of luck!
Baja Rooster is offline
