850 sci - 1075 sci cam specs >
Old 07-01-2016, 08:55 PM
From what I am seeing,
850 SCI camshaft = #8M0043068 old # 496-841341
1075-1200 camshaft = #496-842547T01 old #496-842547
Max recommended WOT RPM
850SCI = 5800
1075SCI =6000
MILD THUNDER is offline
Old 07-01-2016, 09:52 PM
Originally Posted by getrdunn
That would be great. Tks
John
231-233-151 three
just sent it to you.
sutphen 30 is online now
Old 07-02-2016, 07:16 PM
Received 1,494 Likes on 808 Posts
Got it. Thanks for doing that. Current exhaust is cmi etops with dry tails but going to have custom set made for new builds. Can't hardly wait to see the price tag on these. My narrow center to center bites but with any luck I will have different boat by then. Gotta move a little real estate before that happens.
getrdunn is offline
Old 07-02-2016, 07:23 PM
I still kind of find this a little strange as it seems several are under the impression the cams are the same 850sci-1075/1200sci. MT confirmed what I thought also. I just didn't know the difference btwn them.
getrdunn is offline
Old 07-02-2016, 07:32 PM
14 apache's Avatar
Look up the latest serial number 850 and 1075 they look like both engines have the same camshafts.
14 apache is offline
Old 07-02-2016, 07:46 PM
meant to ask last night,,what is the center line of the two engines.
Old 07-02-2016, 08:23 PM
32 5/8". My etops have about 1/16 clearance btwn the closest tubes.
getrdunn is offline
Old 07-03-2016, 09:59 AM
Camshafts listed here http://www.marineengine.com/parts/me...r-and-camshaft
Old 07-03-2016, 10:49 AM
yup,,thats tight.
Old 07-03-2016, 08:43 PM
Originally Posted by MILD THUNDER
Tks for the part numbers. If you run across the cam cards etc please post. I'd like to compare the two. I have the 1075/1200 but not the 850.
Tks
getrdunn is offline
