what transom work is needed to convert TRS to SSMIII drives?
Not to derail this discussion, but besides the "A", what is the main difference between the 3 and 3A?
3a has larger propshaft , larger vertical shaft, larger spur gears, most had straight cut gears which are stronger, and several other beefier parts. Dimension wise, they are the same.
The ONLY way I will convert this boat is if I get the right doner boat to get ALL parts free... I am not going to "out of pocket" 20-25,000 more for drives, the TRS will stay before I do that, at that point I will part mine out and buy one with 3's there are many deals out there...
![Whistle](/forums/images/smilies/whistle.gif)
Edit: I was surprised @ MT picture that showed the #3 being just a bit shorter than the TRS
I love my boat so it would be hard to change in the near future, it would be cool to have 3's on this hull that rides gel rest and solid as a rock, then add some boost after this boat in the 80's would be a blast!
I have a plywood jig for a number III cut out if you need it. I am cutting my holes this weekend, so I won't need it after that. I also know where a complete donor boat is with 3A's, transmissions and motors for 5 grand. The will need to be gone through but that's cheap for all that hardware.
Does anyone have a picture of the inside of the engine room with just a transmission set in? I wanted to see some different ideas on installation.
Thanks,
Thanks,
Thanks,
Thanks,
Can you pm me details or text me about doner? 440-476-4114
Thanks,
Thanks,
