what transom work is needed to convert TRS to SSMIII drives? >
Old 08-04-2016, 04:29 PM
  #31
Craney's Avatar
Tim do you think you would pick up any mph switching to #3 from trs?
Craney is online now
Old 08-04-2016, 04:45 PM
  #32
Full Force's Avatar
No, most likely not, maybe even lose a tad, but the reliability more then doubles, plus I can add boost later that the TRS will not take...
Full Force is offline
Old 08-04-2016, 08:44 PM
  #33
Its very easy to convert from TRS to SSM3...and vice versa. Really the SSM3 has a larger opening, so really not much if any filling in. I converted an SSM3 boat to TRS (all I had laying around at the time). It was minimal work to plug holes again for SSM3.
The SSM3 will move the motor slightly forward (about 2 inches) and you will DEFINITELY gain speed. Have you seen the SSM3 lower compared to a TRS: huge difference, smaller case, nice cone, less resistance etc.
You could also get lucky and be able to raise X dimension without filling too much either.
Ive had 800hp in front of my SSM3s for 300hrs. No issues besides changing oil.
Meanwhile, with TRS I had 415HP and blew a lower within 50 hrs....
Get some and don't look back.
Rambocj7 is offline
Old 08-04-2016, 09:03 PM
  #34
Full Force's Avatar
I figured they took a few more HP to spin so didn't look to gain, maybe maybe not, I hope I get the doner boat I am looking at we will see!!
Old 08-04-2016, 09:14 PM
  #35
Tim, maybe this will help give you a visual. I dug out some gaskets. TRS gasket is the smaller one. 3,4,5 gasket is the larger one.
Attached Thumbnails what transom work is needed to convert TRS to SSMIII drives?-20160804_210911.jpg   what transom work is needed to convert TRS to SSMIII drives?-20160804_210752.jpg
MILD THUNDER is offline
Old 08-04-2016, 09:35 PM
  #36
My inner voice: I should sell this and buy a boat already equipped with what I need.
My outer mouth: F*** that - momma didn't raise no quitter!
Lol
Baja Rooster is offline
Old 08-04-2016, 09:39 PM
  #37
Full Force's Avatar
I love the mistress so I wanna keep it. Now would I go spend 15-25,000.00 on parts to convert? No way.... But.... If I can buy a compete boat at a deal, keep conversion parts I need and still break even selling the rest or make $$? Then yes I will convert the boat I love... That's the plan anyway!!
Lol
Old 08-04-2016, 09:40 PM
  #38
Full Force's Avatar
So if height is same for engines then I don't need to do transom work it looks like.
Old 08-05-2016, 05:33 AM
  #39
That is correct. Only thing is the engines move forward a little. If you find a pair of boxes and run drive shafts you don't even need to move the motors... However the parts for the carriers in the boxes are difficult to find. I do have a machinist that can make all the carrier pieces as well as transom assembly hardware. We just completed a speed master transom assembly that we made all new hardware for with more modern hardware. Inconel pins and delrin bushings throughout.
Black Baja is offline
Old 08-05-2016, 06:46 AM
  #40
F-2 Speedy's Avatar
Received 3,223 Likes on 1,439 Posts
How would it work ( meaning perform ) with a 2 up box mounted in the TRS drive location, essentially raising the X two inches
F-2 Speedy is offline
