WTH is going on with my oil temp
#61
I don`t know about yours but in my case the restriction in volume caused a higher temp in the pan and lower oil pressure. I don`t believe when everything is set up correctly higher oil pressure is going to cause a lower oil temp.
You can see my oil temps going up fast and at that time we were still working out the set up , it wouldn`t go over 5200rpms.
https://www.youtube.com/watch?v=yFIbjPLbM2g
Last season.. Oil pressure was always going down with rpm.. below 40 ish psi @ 6000rpm
Bearing looked fine when taken apart thou.
https://www.youtube.com/watch?v=06RG...ature=youtu.be
(Mild thunder goes for a ride at 4:05)
100 miles since upgrading lines to -12 lines
195* oil temps at WOT is the most I`ve seen after the cooler.
No less than 60 psi .
So much better
So much better
#62
So much better
So much better
Are you running Torco 20-50?
