AFR 325 flow sheets.... anyone ever flow these heads? >
Old 01-06-2017, 10:33 PM
  #91
Full Force's Avatar
Some pics of the hack backyard no name head porter, look pretty good to me and the flow numbers look great, so I think it was money well spent..
[ATTACH=CONFIG]563479[/ATTACH][ATTACH=CONFIG]563480[/ATTACH][ATTACH=CONFIG]563481[/ATTACH][ATTACH=CONFIG]563482[/ATTACH][ATTACH=CONFIG]563483[/ATTACH][ATTACH=CONFIG]563484[/ATTACH][ATTACH=CONFIG]563485[/ATTACH][ATTACH=CONFIG]563486[/ATTACH][ATTACH=CONFIG]563479[/ATTACH][ATTACH=CONFIG]563480[/ATTACH][ATTACH=CONFIG]563487[/ATTACH][ATTACH=CONFIG]563488[/ATTACH]
Attached Thumbnails AFR 325 flow sheets.... anyone ever flow these heads?-afr-heads-ported-1.jpg   AFR 325 flow sheets.... anyone ever flow these heads?-afr-heads-ported-3.jpg   AFR 325 flow sheets.... anyone ever flow these heads?-afr-heads-ported-4.jpg
AFR 325 flow sheets.... anyone ever flow these heads?-afr-heads-ported-5.jpg   AFR 325 flow sheets.... anyone ever flow these heads?-afr-heads-ported-6.jpg   AFR 325 flow sheets.... anyone ever flow these heads?-afr-heads-ported-7.jpg
AFR 325 flow sheets.... anyone ever flow these heads?-afr-heads-ported-10.jpg   AFR 325 flow sheets.... anyone ever flow these heads?-afr-ported-heads-2.jpg   AFR 325 flow sheets.... anyone ever flow these heads?-brodix-intakes-3.jpg
Full Force is offline
Old 01-07-2017, 05:50 PM
  #92
I'm shocked, that on oso, with all the AFR heads that were purchased, nobody has flowed a set of these? How about any others like the 305's, 315's, 335's?
MILD THUNDER is offline
Old 01-07-2017, 06:03 PM
  #93
F-2 Speedy's Avatar
Received 3,186 Likes on 1,423 Posts
I had my 305 as cast with blended bowls flowed for my 540 builds, I don't think I have the data any more.
F-2 Speedy is online now
Old 01-07-2017, 06:04 PM
  #94
Did you dyno those ? I forget
Old 01-07-2017, 06:09 PM
  #95
F-2 Speedy's Avatar
Yes @ Smith power, 630hp
Old 01-07-2017, 06:23 PM
  #96
F-2 Speedy's Avatar
I was running a restricted EFI plenum, pretty sure if I had run a single plane with a 900cfm carb it would have performed much better
Old 01-07-2017, 08:12 PM
  #97
Full Force's Avatar
I was shocked too.... glad I did!!
Old 01-08-2017, 09:19 AM
  #98
The question that was never addressed. what do you have to do to raise your torque curve 400-600 rpm? If you want more top end out of your boat stop chasing peak HP. and work on extending your torque curve!
KWright is offline
Old 01-08-2017, 09:21 AM
  #99
If he extended his "torque" curve, making more torque in the upper rpm band, wouldn't be also me making more peak HP?
Old 01-08-2017, 09:30 AM
  #100
bigger cam
sutphen 30 is offline
