AFR 325 flow sheets.... anyone ever flow these heads? >
Old 01-08-2017, 12:06 PM
  #111
bck
Charter Member#568
bck's Avatar
Since we took a turn towards tq bands, here's how it worked out.
Old engines
663 ft lbs @ 4600 peak
594 ft lbs @ 5800
New intake/ carb/ cam with highest hp and lowest tq.
658 ft lbs @ 4600
666 ft lbs @ 5100 peak
635 ft lbs @ 5800
Final combo as installed
662 ft lbs @ 4600
673 ft lbs @ 5300 peak
627 ft lbs @ 5800
So with making the types of changes available to Tim the torque peak moved up 700 rpm. Torque was down the entire range prior to 4600.
Edit- standby I transposed some numbers... All fixed
Straight bottoms and flat decks
bck is offline
Old 01-08-2017, 12:07 PM
  #112
bck
Charter Member#568
bck's Avatar
Originally Posted by SB
ID 2.5" ? If so, yikes !
I have by far the weakest power ever installed in this boat. Everything is setup for almost 2x the power I'm making.
bck is offline
Old 01-08-2017, 12:20 PM
  #113
Old engines
594 ft lbs @ 5800
658 ft lbs @ 4600
635 ft lbs @ 5800
662 ft lbs @ 4600
627 ft lbs @ 5800
Not far from mine only mine carried a little higher[ATTACH=CONFIG]563525[/ATTACH]
Attached Thumbnails AFR 325 flow sheets.... anyone ever flow these heads?-img_20170108_131557.jpg
KWright is offline
Old 01-08-2017, 12:21 PM
  #114
Originally Posted by KWright
Exactly thats why you dyno in full boat trim[ATTACH=CONFIG]563519[/ATTACH]
those your headers,,the flow thru them suck.we put them on a fountain w/ blowers,,lost 4-6mph(been a while).went back to the gills,,and back to the original top speed.
sutphen 30 is offline
Old 01-08-2017, 12:26 PM
  #115
Couldn't agree more. Wasn't keeping this hull so I was not investing in new exhaust. We feel we left a lot on the table. But if that's what your running that's how you test.
KWright is offline
Old 01-08-2017, 12:34 PM
  #116
F-2 Speedy's Avatar
Received 3,186 Likes on 1,423 Posts
Mine were dyno'd in full boat trim with the CMI sweepers, off the dyno straight into the boat......several dyno shops cant accommodate wet exhaust.
F-2 Speedy is online now
Old 01-08-2017, 12:36 PM
  #117
Not only wet exhaust but also a big enough water tank to pull from with your seawater pump.
KWright is offline
Old 01-08-2017, 12:45 PM
  #118
bck
Charter Member#568
bck's Avatar
Interesting to compare the powerbands. Our peak tq is the same rpm and the numbers are sort of close. You made noticeably more hp however 600 rpm higher.
bck is offline
Old 01-08-2017, 01:10 PM
  #119
Full Force's Avatar
The question that was never addressed. what do you have to do to raise your torque curve 400-600 rpm? If you want more top end out of your boat stop chasing peak HP. and work on extending your torque curve!
a CAM BETWEEN 248-256 DURATION NUMBERS... WILL MOVE both TQ AND hp UP... SAME AS MORE AIRFLOW IN GENERAL, EVEN IF i HAD SAME CAMS, HEADS FLOWING MORE AIR WILL STILL INCREASE POWER... TO A POINT..
Full Force is offline
Old 01-08-2017, 01:14 PM
  #120
Full Force's Avatar
I did...
https://www.youtube.com/watch?v=F5sQmgFHOf4
