AFR 325 flow sheets.... anyone ever flow these heads?
Full force I did check Jim v's flowing results and results varied some from head to head as advertised however intakes were more consistent than exhaust. If you have a good head guy down your way as it sounded like VC mentioned it would probably be worthy to pull them over the winter and get the best out of your heads. What intakes did you have? And also just curious if you had port matched? I'm building these 565's and it can be frustrating with components and combinations available and of course wanting maximum results at a desirable rpm. It's kinda funny how during conversation with different builders/speed shops/AFR themselves even having completely different ways to get to where I want to be. My personal thought is to get as much air into the best flowing ported 320/330 runner. Wil end up with a couple different intakes and carbs from 1050-1250's.
Here is an independent test I pulled off of Stan Weiss. At the lower lifts the numbers were better, higher up the flow was slightly lower. The flow numbers start at .1 and go to .9, they are in .1 increments.
AFR 325 Weingartner Racing Brez N/A 2.30/1.88
4.31
No Pipe N/A 81/63 166/137 236/182 293/226 340/258 358/274 377/280 383/282 386/282
4.31
at 56 hours I would hope so, looking at options pickin g brains, not sure what the plan is yet...still bugs me after spending what I did I have to worry and not be satisfied, the plan was to go 3-4 years without touching them..
I recall your engine dyno sheets being nearly identacle. How were the BSFC. I would imagine you would have caught it on dyno if there was any inconsistencies. Showing any valvetrain weaknesses etc. I had a problem with that on a build with a custom grind cam and it was a combination of aggressive lobe, springs, hyd lifters. Although springs and lifters spec'd by comp I ended up running solids and swapped the springs etc out. It was simply an unstable valvetrain.
engines were 3 hp apart and .3 ft lbs, they were very documented builds, even after I was told I was idiot by oso lol let me lol and see if sheets are saved on laptop
hoping I am worrying for nothing, If I decide to make changes many things will be checked, been problem free, hate to tear into them, but just not pleased with results at all..
I put my thoughts on the lazy performance in the other thread. Im not criticizing you at all I am just stating a fact that an agressivs lobe eats springs for breakfast. If you are loosing pressure 30+ pounds I would get the cam out asap. If its still the close to the same after your initial break in you are ok.
Don't recall the lazy performance post, been too many negative ones I try to forget... I was told these cams will cause me issues, but at the same time the people that told me that have yet to show proof of it... and I am torn on what I will be doing, changing them or keep running them...
sick of taking engines in and out of the boat..
I think the big duration made your airflow "lazy" with big ports/low rpm. A smaller cam would pick up port speed.. Which would translate into HP and torque.
You can either put compression in it or try to play with cams. Yes I agree bob did not do you any favors with this set up.
