AFR 325 flow sheets.... anyone ever flow these heads?
#211
That is simply not the case.
Pictures on the Internet can be very deceiving.
Again, let's stick to the facts and what has been determined by those who have inspected the cams IN PERSON!
#214
The 315's are a great head. You heads, were not ran out of the box from AFR though. They were tuned up , received DEL WEST valves, and some other work before being installed on the engines originally. Those engines came from Chicago, and were dyno'd at Fast Times Motorworks back when they were orignally built.
Fast Times was and probably is still, good peeps.
#215
Sorry, but I've seen quite a few steel billet roller cams come out of engines, with 5x as many hours, 1 that came out of a factory GM engine that had 200k miles on it, and did not have wear marks like that.
Not buying that story. And realistically, if it was a manufacturing defect, that should have no bearing on Bob Madera's end, so I'm not blaming anyone.
#216
Charter Member#568
Unless the person who ported them did a before and after on the same bench with the same procedure, or better yet a before and after on the dyno it's not of much use.
Edit- regarding Tim's head porting
Straight bottoms and flat decks
#220
