AFR 325 flow sheets.... anyone ever flow these heads?
Don't recall the lazy performance post, been too many negative ones I try to forget... I was told these cams will cause me issues, but at the same time the people that told me that have yet to show proof of it... and I am torn on what I will be doing, changing them or keep running them...
sick of taking engines in and out of the boat..
Was this the cnc chamber and bowl head?
Here is an independent test I pulled off of Stan Weiss. At the lower lifts the numbers were better, higher up the flow was slightly lower. The flow numbers start at .1 and go to .9, they are in .1 increments.
AFR 325 Weingartner Racing Brez N/A 2.30/1.88
4.31
No Pipe N/A 81/63 166/137 236/182 293/226 340/258 358/274 377/280 383/282 386/282
4.31
not yet, I sent cams I figure when cam time comes (soon) we will talk and see, going to run numbers by a handful of MARINE guys, a buddy is talking to Teague also gonna try to get his input too..
Would have been nice to see what they flowed stock, then ported.
Thats with a pipe on the exhaust, so keep that in mind when comparing flow numbers to other heads. Most are not flowed with a pipe, and will show less cfm without the pipe attached
