AFR 325 flow sheets.... anyone ever flow these heads?
#421
Charter Member#568
How many hours have you logged on that scarab in the past several years? Or are we just continuing to shell out some money, stiff a few people, bash a few people, and yet, still had a boat that hasnt seen water in how long? Your dyno sessions were a joke. Your knowledge of engines are a joke. If you knew 1/10th of what you act like you do, we would be seeing some pictures and videos of your boat tearing it up on the water, instead, we hear about the 6 years of dyno testing, trying to chase down 40hp with 100 different combinations of parts, none of which have actually been proven to work out in the field.
From where i stand , it would be prettt easy for Tims mistress to smoke your boat, considering its a yet another "work in progress" like most of the oso experts boats. The typical Bob madera is the best crowd, that have 15 minutes of run time , zero speed gain data from their mods, but think a "cam" and head package, is putting them out front in the poker run circuit.
I got your high resolution cell phone pic right here. Anytime you wanna line up that scarab on lake michigan, let me know. Ill be sure to take cash only though, as from what I hear, your not very good on paper.
Straight bottoms and flat decks
#424
Aww, c'mon MT where the love? Me and you have soo much in common. We both have great resolution, Google for a search engine and we've both built the exact same amount of engines. How many boats have powered by mild thunder on the valve covers? We all know you've spec'd a lot more cams than Bob, but now you even know more than Cam Motion. You have no problem keeping Tim stirred up when it benefits you to badmouth his cams but what other advice have you given him other than getting him to tear apart perfectly good engines to further your goals?
As for advice for Tims engines, lets see.
Tim you should take a look at those valve guides . (Turned out they were tight)
Tim, you should replace those valvesprings, they are not endurance springs. (Turned out they are not)
Tim, you should check your spring install heights ...(turns out they were all over the place)
Tim, you should upgrade valve seat materials if you could afford to do so (several members here have seen excessive valve seat erosion over a short time)
Tim, you should pull your intakes and take a look at the lobes (even kip from cam motion admitted they shouldnt look like that contrary to what you have heard)
Tim, ill come down to help you with your dyno session.
And about a million calls and texts between him and I over these engines the past 2 years.
As for the 10 dollar software programs, some very high end builders utilize modern software for engine development . Its not the end all, but it is certainly better than throwing a dart at a page of a catalog.
So, being that you live so close to marine kinetics, and have had it with all the engine builders that failed you in the past, why didnt you have Bob M dyno your engines? Or assemble your engines? Oh thats right, he doesnt do that.
#425
Charter Member#568
As far as coming there to race or running my boat, I keep my dick in my pants when I'm not using it, not on my trailer. You should take yours out a little more often at home and you wouldn't need it to be stroked so much here.
#426
Thx for all the help btw! I can say mild has helped me more then anyone on Oso... anyone.
Youre right! I never even turned a wrench!
#428
Charter Member#568
Tim's got it all figured out this time, you've taken good care of him. I'm all done here.
#430
I do however have a boat. A boat that runs. I have tuned and helped many friends turn wrenches, and get their boats running better, as well as my own several boats ive owned.
