AFR 325 flow sheets.... anyone ever flow these heads? >
Old 02-22-2017, 06:14 AM
  #651
Full Force's Avatar
This ones perfect, they were nearly identical on dyno, wonder if it changed after hmm
[ATTACH=CONFIG]564985[/ATTACH][ATTACH=CONFIG]564986[/ATTACH]
Attached Thumbnails AFR 325 flow sheets.... anyone ever flow these heads?-img_9467.jpg   AFR 325 flow sheets.... anyone ever flow these heads?-img_9466.jpg
Full Force is offline
Old 04-06-2017, 08:16 PM
  #652
Full Force's Avatar
Just waiting on weather now... Hoping to drop them Saturday..
[ATTACH=CONFIG]566148[/ATTACH][ATTACH=CONFIG]566149[/ATTACH]
Attached Thumbnails AFR 325 flow sheets.... anyone ever flow these heads?-boat-engine-4-6-17-b.jpg   AFR 325 flow sheets.... anyone ever flow these heads?-boat-engines-4-6-17-.jpg
Old 04-06-2017, 08:36 PM
  #653
Looks nice Tim. Hopefully you can finally put some closure to this saga.
endeavor1 is offline
Old 04-06-2017, 08:43 PM
  #654
Full Force's Avatar
Thx, I hope so to... maybe I wills see results worth the latest adventure... I think I will...
Old 04-06-2017, 09:02 PM
  #655
Received 1,494 Likes on 808 Posts
I would imagine you've sucked a few beers out of that fridge over the last several months. Good luck. I would think the intake and porting itself you'll notice some gains. Regardless seems like you have it wired this time around.
Would be nice for first run to leave hatch off and run a 1150 dom with adapter on one engine. I'd bet you'd see about 200 plus more rpm. BTW Engines look nice.
getrdunn is offline
Old 04-06-2017, 09:07 PM
  #656
They look good tim...would look better in the boat tho get to work
1989mach1 is offline
Old 04-06-2017, 09:11 PM
  #657
Full Force's Avatar
Thanks bud, been a long winter of BS and lots of $$
talked to 2 carb guys both think under 6000 rpm the 4150 style 1050 is plenty for my application, Doms won't fit anyway that's why I never did them 3 years ago when I got all new, same reason I did not do tall decks..
As far as gains... I thin k from what I did I will see 40-60 hp, ish, MT Joe agrees also..
I see it this way if I gain ..
headwork and proper springs 10hp
cams 10hp
intakes 10hp
warmer oil 10hp
that's a very realistic 40 hp, I made 630 in marinbe trim so that's probably 660-670 in dyno trim the way they were before, that should put me right at 700-725 depending actual gains of work and issues we addressed, maxed out what I can make with existing parts..
almost excited to see... hoping no let downs...I was not going to post, but some people actually care to see how it is, I am done with any drama and negativity, I have better things to worry about, if it goes negative again I'm out.
Old 04-06-2017, 09:12 PM
  #658
Full Force's Avatar
See ya Sat!!!?? LOL
Old 04-07-2017, 12:13 AM
  #659
articfriends's Avatar
cams 10hp
intakes 10hp
warmer oil 10hp
And dont forget, 2 different 1050doms made pretty much exactly the same hp/tq as your 1050QF at 655 hp/6200-6300 so unless you went bigger yet and your motor actually needed more airflow a dominator would do ZERO other than look cool
articfriends is offline
Old 04-07-2017, 04:50 AM
  #660
Full Force's Avatar
That's true also.. haha
