AFR 325 flow sheets.... anyone ever flow these heads? >
Old 04-10-2017, 11:24 AM
  #681
Originally Posted by bck
I had someone lift the complete engines with straps wrapped under the primary pipes of the headers. I wasn't thrilled with that but was told he did it all the time.
that is how i used to pick the engine out of my drag boats,8 grade 8 bolts and 4 pipes welded to the flange seems plenty strong to me.
mike tkach is offline
Old 04-10-2017, 11:43 AM
  #682
vintage chromoly's Avatar
I just run a choker under the intake.
That said, it is amazing what a grade 5 bolt is rated for.
I always worry more about the threads in the intake as apposed to the bolts themselves.
vintage chromoly is offline
Old 04-10-2017, 11:57 AM
  #683
bck
Charter Member#568
bck's Avatar
I just didn't want all that weight on the header welds. Creating a leak if there was a weak point was my concern.
Straight bottoms and flat decks
bck is offline
Old 04-11-2017, 08:29 PM
  #684
Originally Posted by Full Force
This ones perfect, they were nearly identical on dyno, wonder if it changed after hmm
[ATTACH=CONFIG]564985[/ATTACH][ATTACH=CONFIG]564986[/ATTACH]
Curious if that's your jetting plus a PV or are your PVs plugged?
endeavor1 is online now
Old 04-11-2017, 08:46 PM
  #685
Full Force's Avatar
Has PV in front.
Full Force is offline
Old 04-11-2017, 09:16 PM
  #686
Received 1,494 Likes on 808 Posts
Got one of your questions answered. port and stbd are different jetting.
getrdunn is offline
Old 04-11-2017, 09:26 PM
  #687
Full Force's Avatar
I thin k we figured that out to be the secondarys was hanging up a tad, Smitty saw on dyno...
Old 04-11-2017, 10:40 PM
  #688
Ah. I tried to keep up my best but missed that one. Btw any projected date to hit the water? Hope all goes well. "5,850".
getrdunn is offline
Old 04-12-2017, 04:31 AM
  #689
Full Force's Avatar
Thinking I will have it running this weekend, hit water in couple weeks, been very busy lately.. boats been as I can get to it..
Old 04-12-2017, 10:15 AM
  #690
articfriends's Avatar
When we got carb we saw secondarys werent square when primarys were, norm says its a common occurrence, could be possibilty why carbs needed different jetting. I never gave it a lot of thought before norm showed me that. The 102 mm tb we tested on my 548 had same issue, once throttle stop was ground on to get throttle blade perfectly square it picked up 10% airflow.
articfriends is offline
