AFR 325 flow sheets.... anyone ever flow these heads? >
Old 05-07-2017, 09:36 PM
  #741
Received 1,494 Likes on 808 Posts
Just curious if you could try a set of 3 blade 25p mirage props. What are are most running successfully on those hulls?
getrdunn is offline
Old 05-08-2017, 05:08 AM
  #742
Full Force's Avatar
That's what I had before, tried again I cannot keep them hooked up... 19% slip... all the guys running mid 70's or more are running a 4 blade for same reason..
Full Force is offline
Old 05-08-2017, 06:39 AM
  #743
Originally Posted by Full Force
Ok update as of now...
Gained a solid 2-300 rpm, lake was FLAT and we know how that is with a old straight hull slug, lol
This was 24 hydromotives... I put on 26 bravo1 but lake kicked up too much for a good test
First the water was flat.. THEN too rough.. MAN, that's a picky hull...
Good luck.. I'm Betting the Bravo's will be a tick faster than the Hydros on the top end
Boatally Insane is offline
Old 05-08-2017, 08:58 AM
  #744
Full Force's Avatar
Was not too rough to boat, but you can't get good wot speed run when you are leaving the water a lot... the video was dart in morning, later the lake kicked up enough to not get a good run in...
Funny thing years ago my best speed ever was spit flat water... kinda odd
Old 05-08-2017, 04:20 PM
  #745
you mean efi adds lots of hot air ??
hotrodford is offline
Old 05-09-2017, 05:23 PM
  #746
Gotcha. You'll. Get it. How'd it feel overall. Any. Difference in midrange or throughout?
getrdunn is offline
Old 05-09-2017, 09:14 PM
  #747
Full Force's Avatar
So far 24 hydros worked best need to try more ... did 74.3@5500 with them
Today I did 26 beavo1, 72.5@5200
Old 05-10-2017, 06:48 PM
  #748
Hang Time 27's Avatar
This was 24 hydromotives... I put on 26 bravo1 but lake kicked up too much for a good test I didn't even try yet
I am trying to Located 25 rev4 also to try
They don't come up as a pair too often, that's for sure, but there does seem to be more of them out there - could never find them a few years ago.... and you can never have too many props, lol... .
I'm just glad I only need singles....
Attached Thumbnails AFR 325 flow sheets.... anyone ever flow these heads?-img_1481.jpg
Hang Time 27 is offline
Old 05-10-2017, 07:08 PM
  #749
Two left hands and a right hand on ebay right now - 25's - at 200, 450, and $475. Not a matched pair, but good enough for testing - if you really like them, it might be worth having them matched up later, and if not, sell em off...
Old 05-11-2017, 05:07 AM
  #750
Full Force's Avatar
Gtried 26 Bravo1 the other night, only saw 72.5@5200... so those are too big... now I need to try a 22 Bravo1 and see if raising rpm helps, also the Rev4 still... and maybe 23-25 Hydro.
