Cam and valvetrain longevity....??? low duration high lift...
#1141
mine to
![Cool Smiley 011](/forums/images/smilies/cool-smiley-011.gif)
![F-2 Speedy is offline](/forums/images/statusicon/user_offline.gif)
#1142
Must have had some valves not closing all the way also. Could explain the overly rich looking chambers, down on power, chamber cc's? etc. Would be nice to know what installed height was suppose to be in comparison to what is shown.
![getrdunn is offline](/forums/images/statusicon/user_offline.gif)
#1143
you are,,but remember this too.the springs seats in the head could also be all over the place.plus the seat on the valve could be in a different height also,,stacking the tolerances.
key is to put the head in seat cutter machine and index all the seats.see where they are.when I cut them,there dead nutz on.
![sutphen 30 is offline](/forums/images/statusicon/user_offline.gif)
#1144
So go by the furthest one in and cut all to same depth with new seats? Time to bake your heads in the wife's oven rather than a roast. Get lucky at 475 they might just fall out.
#1145
Reminds me of the shop that replaced the seats and rebuilt my old heads. Install heights all over the place. However, those were 15 year old castings, that been thru a few hands. If the install heights varied that much on a new set of heads that never been cut, I would think that is , well, not so great. At the very least, even if the seat height varies that much, or like sutphen said, the casting itself having different heights of the spring perch, you would think that someone would go thru them, record all install heights with the retainer and locator installed, and shim accordingly, so at least, all the springs have equal pressures. .040 variance, is alot!
Any good shop worth its weight, would blueprint a set of heads so to speak, and check each valve. Not check one valve, throw 16 springs in there, and call it good.
![MILD THUNDER is offline](/forums/images/statusicon/user_offline.gif)
#1146
I thought this was all checked when the lifter stuck ?? before it went back together.......spring issues ect.
#1147
115
![SB is offline](/forums/images/statusicon/user_offline.gif)
