Cam and valvetrain longevity....??? low duration high lift...
#1281
Heres a thread I had started about tims combo, in another forum. If anyones interested.
http://www.speedtalk.com/forum/viewt...hp?f=1&t=47746
![getrdunn is offline](/forums/images/statusicon/user_offline.gif)
#1282
So tempted to part my engines out and buy hp500's used, would have better luck lol
![Full Force is offline](/forums/images/statusicon/user_offline.gif)
#1283
MT - That GM 572 cam is a Crane Cam.
![SB is offline](/forums/images/statusicon/user_offline.gif)
#1286
I wonder if those marine kinetics custom designs go thru testing like that, to find out which spring pressure is needed, and how stable the valvetrain is , and for how long.
![MILD THUNDER is offline](/forums/images/statusicon/user_offline.gif)
#1287
I'll sell you a like new never used one dirt cheap so you can test it and find out lol
![Raizorsedge is offline](/forums/images/statusicon/user_offline.gif)
#1289
I have called a big talked to Bob and I also called Cam Motion today. My cams are induction hardened 8660 billet steel premium grade cores. There are some better but many not as good. They are better than what the OEM's use for their hydraulic roller cams. After this discussion I am not worried about hardness issues or the cam specs. My boat runs great any it should for a long time.
After following this long thread and others it seems Tim's issues are more than a Bob M issue and more about the engine assembly and also putting all the right parts together to reach his goal. Maybe he should have had someone help with final assembly and checking all the parts to confirm they were all correct.
![ARB38 is offline](/forums/images/statusicon/user_offline.gif)
#1290
Really? Who said that? bob? Please tell me what's wrong with assembly? Every last detail was checked and logged I bet my build sheets have more info then 90% here....
So let's hear it... Bob tell you that? What did Bob say my issue is fault of? His crap cams? The wrong springs? What?
