Cam and valvetrain longevity....??? low duration high lift...
#1731
The .750 wheel will handle a higher acceleration rate than a .700 wheel. Most of the "modern lobes" we are using these days have much faster acceleration rates. You can have two cams with 240* .700" lift. They can have very different acceleration rates. The more acceleration you have in the lobe the larger the wheel you need. The larger wheel acts like a gear reduction...
![MILD THUNDER is offline](/forums/images/statusicon/user_offline.gif)
#1733
I can get .750 wheel Johnson solids at a great price, just not sure I want to go with Solids yet... removing exhaust for lashing sounds like it sucks... thought I may be able to keep pushrods the same if I go to short travel hydraulic, but Randy said that will change... that makes solids much more of an option if I have to buy pushrods anyway.
![Full Force is offline](/forums/images/statusicon/user_offline.gif)
#1734
Since we are talking about lifter designs, what are the pros and cons of running a "swedged" axle , vs an axle that is held in place by a wire lock?
I did some googling like havoc40 suggested, and stumbled on this topic where on another site they were comparing johnsoms vs morels . Here a guy claimed his "swedged " axle came out of his johnson lifter.
http://speedtalk.com/forum/viewtopic.php?f=1&t=42149
#1735
I expect 250 pages before Tim even begins assembly! Lol
I never gave much thought to lifters before watching a show about a NASCAR engine builder who used an electron microscope to check brand new lifters. The rejection rate was quite high.
![Baja Rooster is offline](/forums/images/statusicon/user_offline.gif)
#1738
Swedged axle vs. wire clip axle is another highly debated topic. Again, what does this have to do with the issues here? Tim did not have a bearing failure or even a lifter failure.
![Havoc40 is offline](/forums/images/statusicon/user_offline.gif)
#1739
I'm really not getting into the possible cause of failure because I don't know enough information. More guesses and accusations will not help this situation. I actually build engines and know what it takes to figure out a problem like this. You need quality measuring/inspection tools and inspect each and every component at the same time. It's a system and needs to be analyzed as such. I think once he goes with parts that are proven to work he'll have reliable engines for years to come.
Havoc40/ Randy, what spring pressure is the 2126 lifter designed to sustain? That seems to be absent from the website. Thanks. Edit- is it possible to categorize it, could you say xxx lbs should be good indefinitely, xxx lbs should be checked/ replaced after a certain time, xxx lbs shouldn't be used at all etc ? Thanks
#1740
That particular lifter is a Topline Hy-Lift product. They continue to use the Johnson name even though we own the registered trademark, it's a legal nightmare. You can tell by the flat bottom. All of our lifters have a relief cut, up the sides of the roller to allow for more duration. Been that way since late 90's.
