Cam and valvetrain longevity....??? low duration high lift... >
Old 11-30-2016, 07:07 AM
  #1801
SB
Received 3,177 Likes on 1,433 Posts
Originally Posted by Drake22.250
1799 post already and we haven't had any snow one the ground....
We have. In fact, we had a white Thanskgiving. I'd rather it on Christmas. Oh well.
SB is offline
Old 11-30-2016, 07:09 AM
  #1802
Full Force's Avatar
Hahahah true!
Full Force is offline
Old 11-30-2016, 08:32 AM
  #1803
bigboat28's Avatar
We've had snow too.
bigboat28 is offline
Old 11-30-2016, 08:58 AM
  #1804
Originally Posted by bck
I'd send one of the cams to Randy/ Johnson if they'll look at it. No sense sending 2 cams that look the same to CM.
I told Tim early on I'd be happy to run the cam through the lab. I'm close with Kip and he'll be involved with everything. Everybody involved is trying to make sure this gets resolved and the engines are reliable.
Havoc40 is offline
Old 11-30-2016, 09:16 AM
  #1805
Drake22.250's Avatar
live near Fermi Nuclear plant, no snow here......don't have to put popcorn in microwave just leave on counter.
Drake22.250 is offline
Old 11-30-2016, 10:25 AM
  #1806
Originally Posted by SB
Almost 200 pages on a cam wear issue that has yet to be rectified and we are blowing out someone from a lifter company who just got here? Jeez, he's not even an outside sales rep.
My goodness.
Youre right. I should have known better. Reminds me of when you and your buddies ran Scott Foxwell out of here .
Foxwell actually offered some tech advice.
Scott, you been preaching about the shrouded wheel lifter concept , and how fork lifters spread. Have you ran either the morels or johnsons in any bbcs turning 6,000, 6500, 7000rpm with 500 plus lbs of open pressure ? If so, what were the results ? Did the forks spread? Any signs of wheel tracking ? Valve float? How many seasons or hours ?
MILD THUNDER is offline
Old 11-30-2016, 10:59 AM
  #1807
We have ran Fork style lifters over 10,000rpm 500lbs on the seat. I forget the open. But never had valvetrain issues. 1.250" lift
Black Baja is offline
Old 11-30-2016, 11:07 AM
  #1808
The only reason I see the necessity to make the lifter with a shrouded wheel is so you can make the body out of a cheaper material.
Old 11-30-2016, 11:10 AM
  #1809
same here,,but we're only a measily 1.195". of course,its only for 6.95secs.and this year,,maybe less.
sutphen 30 is offline
Old 11-30-2016, 11:11 AM
  #1810
Do they make any 904 or larger body lifters, with say , a .750 wheel in a shrouded body?
