Cam and valvetrain longevity....??? low duration high lift...
I have a feeling it's not so much the couple of grand more so the extra power and speed gained. However with that said what's that magic cam so it's not all a waste of time and money. I know of a custom grind that I am certain would work well and achieve his goals but would like to see him get his heads flowed to see how close they are to advertised. At least one anyway. More power to be had with those heads.
![getrdunn is offline](/forums/images/statusicon/user_offline.gif)
Mild has a grind that seemed to really wake it up on the computer, the existing numbers were within a few HP of my dyno sheet, I am going to contact a few to get overall opinions, Dean Gellner just did 540's making 706, I am going to talk to him, and Cam Motion direct, and a few others like Comp, Erson and such...
what is your grind? EVERYONE has so fasr told me I need to be in the 250'[email protected].... to start..
I have a feeling it's not so much the couple of grand more so the extra power and speed gained. However with that said what's that magic cam so it's not all a waste of time and money. I know of a custom grind that I am certain would work well and achieve his goals but would like to see him get his heads flowed to see how close they are to advertised. At least one anyway. More power to be head with those heads.
![Full Force is offline](/forums/images/statusicon/user_offline.gif)
If I recall you were 241/246-670 or so. I may have stated this in one of your other threads however valako runs like something real close 236/244-707 gross lift on the intakes. Custom ground hyd roller and runs solid roller and springs. No issues. Been running that way for years and that lift is with 1.8 rockers. You'd think if any combo would have premature valve train wear or failure that would but seems to be pretty trouble free.
![SB is online now](/forums/images/statusicon/user_online.gif)
Looks like another Cam thread. What most don't realize is when the lift increases on a Lobe , the Duration also has to increase . Because of Valvetrain Stability. The magic bullet , high lift low duration cams, have a built in flaw . There is not enough Duration on the lobe to control bounce and loft. Everyone thinks that a lifter follows the lobe exactly. Not true. You have what is called Loft , at increasing RPM , the Lifter does not want to follow the lobe . Inertia takes over and objects in motion tend to stay in motion.
Thus the lifter jumps the nose of the lobe , and tries to land gracefully on the backside of the lobe. If it lands to far down the lobe , it bounces. Which sets up a Harmonic through the whole Valvetrain , The only solid points to dampen the Oscillations are , the Lifter and Lobe interface , and the Valve to Seat Interface. Resulting in Valves and Valve Seats that have been beaten to **** , Or Lifters that break due to the severe harmonic ( Bounce ) that is placed on them.
I know the theory , and the brain trust , behind the Magic Bullets. Trust me there is no magic bullet. If a name brand cam company doesnt have the lobe
configuration your looking for, There is a good reason why. That Reason is Thousands of Hours , and Millions of Dollars of R&D into Master Cam Lobe developement. That
actually works .
actually works .
![dunnitagain is offline](/forums/images/statusicon/user_offline.gif)
Lifters are always the scape goat for a number of other valvetrain issues I think.
My spring pressures are 218/545 and the standard Morels haven`t failed me in 4 years and this year I`ve run em a little past 6200rpm.
![ICDEDPPL is offline](/forums/images/statusicon/user_offline.gif)
I know quite a few guys, including myself, who have been running morels with great sucess. And they arent a basic 600hp build. Talking 800, 900, 1000, and 1200hp engine's that have seen north of 6,000rpm. Icdedpples 900s have some time on those lifters, as have mine. How many hours have you got on the johnsons so far? And whats the cam/spring combo?
I know some have had some issues with them, and some noise issues. I will say this, if you have a hyd lifter capable of 7000rpm and 600lbs over the nose, the clearances are tiny, and very precise in those lifters. They do not tolerate any debris in the oil, and an immaculate engine assembly is imperative.
Mine did have some lifter noise after this springs reassembly. It did however, go away after a little run time. They arent quiet like a stock gm lifter though. But then again, i wouldnt pull my engines to 6500 with a stock gm lifter and 500 plus lbs of open psi , with a blown engine and heavy azz valves..
Not sure if id say they are junk. Outside the oso world, they are still the lifter of choice for a serious bbc build thats needs a hyd lifter capable of rpm. Their lifter bodies and tolerances are far from junk material or machining .
![MILD THUNDER is offline](/forums/images/statusicon/user_offline.gif)
