Cam and valvetrain longevity....??? low duration high lift...
#292
As many times as guys like to mention what happens when you go too big on duration, theres 1000 times more scenerios, where not enough duration, was causing a lack of power. If not , we would all be running stock cams in everything.
How many guys many years ago, took out a stocker cam from a chevelle, gto, buick, stock 365hp merc motor, or any of those, and made more power , by going to a camshaft with "less" duration.
Of course if you get carried away, then things go bad.
![MILD THUNDER is offline](/forums/images/statusicon/user_offline.gif)
#294
found this on an old thread
The standard marine 8100 cam is:
204º/209º @ .050”
.282”/.284” Lobe
.480”/.483” Valve
118º
The HO cam:
224º/233º @ .050” (222º/232º)
.300”/.300” Lobe
.510”/.510” Valve
114º/115.5º
The cams are ground on the C swap core.
496 MAG (375hp)
Block: Cast Iron
Cylinder Head: Cast Iron (with exhaust valve seat inserts)
Intake Manifold: One Piece coated Cast Aluminum
Crankshaft: High-Density Nodular Iron (with undercut and rolled fillets)
Pistons: Hypereutectic Cast Aluminum
Connecting Rods: Forged 1141 SAE Steel (short -peened and magnafluxed, with 9-mm diameter connecting rod bolts.
496 MAG HO (425hp)
Block: Cast Iron
Crankshaft: Forged Steel (with undercut and rolled fillets)
Both are internally balanced. Besides the above, there is a different cam and programming between the two.
204º/209º @ .050”
.282”/.284” Lobe
.480”/.483” Valve
118º
The HO cam:
.300”/.300” Lobe
.510”/.510” Valve
114º/115.5º
496 MAG (375hp)
Block: Cast Iron
496 MAG HO (425hp)
Block: Cast Iron
![F-2 Speedy is offline](/forums/images/statusicon/user_offline.gif)
#295
That's why loading as low on dyno as possible can help us to put all the #'s together .when looking at various charts.
Most black motors, if not all, can pick up a bunch of power at planing rpm and all the way up and beyond with a modern performance cam change.
However, when you are near maximized, changing duration will just change rpm range.Add some up top, you'll lose on bottom..and vice versa.
Hopefully I wrote that so must understand. Hard to type my brain sometimes. LOL.
![SB is offline](/forums/images/statusicon/user_offline.gif)
#296
Tim I've kinda got away for a bit but back to original thread I'm curious what most are doing for 540 build combos in your boat. Your builds obviously need to be tailored around your specific application is for certain. Just moving forward if you reached your goals with said cam you posted and optimize head and intake velocity with pushing peak torque to near 5k what end result would be. I know Joe among others touched on how much rpm above peak torque you would end up propping to. I guess in a nutshell regardless of hp, "what are others running peak torque at with your specific boat"? It's obvious what you have isn't working so I'm just thinking out load but will probably get bashed for that. What should peak torque be at for your application? Obviously makes a big difference from let's say a cat or even fountain.
![getrdunn is offline](/forums/images/statusicon/user_offline.gif)
#297
Geronimo36
Both new and old cams have the 4/7 swap. It was replaced with a 252/261 113LSA .663/.671 if my memory serves me correctly. I wanted to go to a .400 lobe though and I'm going to give it a try here very shortly.
The reason it performed better then what was in there is the higher lift profile combined with the full CNC Brodix heads. The comp cam wasn't bad, it just wasn't ideal so I had it tweaked a little bit.
![Panther is offline](/forums/images/statusicon/user_offline.gif)
#299
Tim, so what were the cam specs used in your old 565 cu in engines with the Pro-Comp heads that were supposedly stronger?
![Gimme Fuel is offline](/forums/images/statusicon/user_offline.gif)
#300
Interesting thread regardless. Lots of info.
