Cam and valvetrain longevity....??? low duration high lift...
#411
Wonder if bob thought I wanted to spin 5500?? I have sheet I faced to him at home, said I wanted 700@6000
With that info, now keep in mind, that was with a flow cfm, of an average aftermarket bbc head. If I was to go off AFR"s advertised numbers, for the 325 CNC ported head, the program would show for tims 540,
242/248 duration at .050, for a 5500RPM max engine combo. Tim has 241/246. Pretty darn close right? By looking at his dyno sheet, would it be safe to say, his engine was about done making power around 5500?
Maybe its just a coincidence. Or, maybe this program, is halfway accurate.
![Full Force is offline](/forums/images/statusicon/user_offline.gif)
#412
How about that engine in the article SB posted. 502ci, afr 325's, looking to make max power at 6000rpm. It actually peaked at 6200, but....using a tight lash setup, program says
245/252 @ .050.
That engine, had a 245/250 solid.
245/252 @ .050.
![MILD THUNDER is offline](/forums/images/statusicon/user_offline.gif)
#414
Its just a software program, and we all know how computer programmed engine builds can go. At the end of the day, you're exact combo, was spec'd from a combination of software, and gathered data. Problem occures, when you're relying on second hand data, to spec' engines for someone. There's a ton of factors involved.
Its still best to validate things on an engine dyno, making changes 1 at a time. Thats engine development.
#418
Joe i just looked at the difference in 502 and 540 which is apprx 8%. Looking at the specs of solid cam in 502 build that was posted and added the 8% into cam numbers. For chits and grins to see what it software/program would show. Just throwing 8% more cam at than the 502.
![getrdunn is offline](/forums/images/statusicon/user_offline.gif)
#419
crane 139651 244/[email protected] .632 lift.just information,nothing more nothing less.edit in 114 lsa
![mike tkach is offline](/forums/images/statusicon/user_offline.gif)
#420
or 5 lbs boost and then your troubles will begin,drives,transmissions crapping every weekend.pick your poison tim!
