Cam and valvetrain longevity....??? low duration high lift... >
Old 09-23-2016, 06:48 AM
  #451
Originally Posted by Full Force
Same? I was told they are, then the 3a and 4a is 2" shorter over a 3..?
4A!!!?? No such thing.
I wanna say a 3 is 1 or 1.5 shorter than a trs. A #4, is about 5.5", shorter than a 3/3a.
MILD THUNDER is offline
Old 09-23-2016, 06:55 AM
  #452
Ssm 3 is 24.311
Trs is 24 7/8 iirc
Unlimited jd is offline
Old 09-23-2016, 06:56 AM
  #453
94 top gun with 700's and trs did 81
Old 09-23-2016, 07:48 AM
  #454
Full Force's Avatar
Top gun is faster hull then mistress, my chits a SLUG!
Full Force is offline
Old 09-23-2016, 08:00 AM
  #455
Full Force's Avatar
I'm not up on SSM drives, just what I thought oops
Old 09-23-2016, 08:52 AM
  #456
cigrocket's Avatar
Nope No 4A. However some had small shaft 19 splines and they were upgraded to 26 Spline. Parts were always tough for the 4's because they just didn't make many and then stopped. Short span of years.
cigrocket is offline
Old 09-23-2016, 09:03 AM
  #457
Yep. I have small shaft 4's. They use the same lower gearsets as the big shaft drives if i recall. The upper gears are different due to the polygon vertical shaft . Some 4's came right from merc with big propshafts
Old 09-23-2016, 10:34 AM
  #458
40 Hawk did 82 on its best day with those motors IIRC
Maybe Tim should buy the Hawk
endeavor1 is offline
Old 09-23-2016, 10:53 AM
  #459
Ran 84 once for me and I believe Kevin saw it there too with prop work. I cheated with 55* and good gas. Imco's don't make it a fair comparison.
But the 40 with Konrads runs 75 with 630HP 540's. For Sale too!
TxHawk is offline
Old 09-23-2016, 10:58 AM
  #460
The 40 hawk had a 22 deg deadrise if i recall.
