Cam and valvetrain longevity....??? low duration high lift...
#712
For the record i never said that, I may have implied it..... But Tim back to your exhaust, IMO and JUST MO. a N/A motor will benifit greatly from the correct exhaust that will promote Scavenging exhaust gases from the Cyl. BUT only if you have the correct valve timing events to work with the exhuast.. Back in my flat bottom Sanger 454 tunnel ram set up Basset made some awesome exhaust scavenging headers, but hard to find ones to work within the confines of an enclosed engine compartment. so I digress.. My point being that with all the of your other power issues IMO a cam and exhaust change may be in order.
![abones is offline](/forums/images/statusicon/user_offline.gif)
#713
For the record i never said that, I may have implied it..... But Tim back to your exhaust, IMO and JUST MO. a N/A motor will benifit greatly from the correct exhaust that will promote Scavenging exhaust gases from the Cyl. BUT only if you have the correct valve timing events to work with the exhuast.. Back in my flat bottom Sanger 454 tunnel ram set up Basset made some awesome exhaust scavenging headers, but had to find ones to work within the confines of an enclosed engine compartment. so I digress.. My point being that with all the of your other power issues IMO a cam and exhaust change may be in order.
![Crude Intentions is offline](/forums/images/statusicon/user_offline.gif)
#714
[QUOTE=MILD THUNDER;4486590]Anybody running a well designed solid roller, see major lash changes at 65 hours with a new aluminum head?[/QUOTE
Good point.
To illistrate Joe's point My 396 Camaro engine is running a soilid Roller 109 lobe sep, 263/274@ .50, ,688/.686, with .025 lash very stable lash stays put.
Good point.
#715
Was a ultra dyne 276/284 .750 lift after lash.
![14 apache is offline](/forums/images/statusicon/user_offline.gif)
#717
Your doing this now, because you did not change cams when everybody told you too. you did however enjoy a season of boating, which you may not have if you had everything ripped apart. As for the whole exhaust issue.. I have SM's to go on my new motor. Even if I was building a much bigger motor, I still wouldnt be using headers. I have heard too many horror stories. I would rather give up a few hp and a couple mph over giving up a season and a lot of cubic dollars because a header cracked and killed a motor, Its generally more fun to go slow on a boat than to sit on the dock watching boats or sit in the garage fixing them.
![phragle is offline](/forums/images/statusicon/user_offline.gif)
#718
That's no excuse that "doing now because I was told to change cams" first of all I am not sure if that's the issue yet, second... At the time nobody could provide proof of issues to me, third... I pad bob m to spec me a long term successful build and it's been everything but that!!!!!! I love how this gets turned on me, my fault for listening to the guy that was highly recommended to me and it's my fault... Sick of hearing that, I could have dropped in a crate engine with better results...
![Full Force is offline](/forums/images/statusicon/user_offline.gif)
#720
![MILD THUNDER is offline](/forums/images/statusicon/user_offline.gif)
