Cam and valvetrain longevity....??? low duration high lift... >
Old 09-30-2016, 04:11 PM
  #741
Originally Posted by Black Baja
Looks like a cast cam
Looks like several other MK cams that were removed from engines after a short time.
Maybe ground thru the hardening ?
MILD THUNDER is offline
Old 09-30-2016, 04:17 PM
  #742
God forbid you say hey maybe Bob screwed up. What makes him so god like? Just curious why some of you deem him untouchable and he can't make mistakes.
Crude Intentions is offline
Old 09-30-2016, 04:18 PM
  #743
I had a motor swallow a lifter this summer and it's lobe doesn't look that bad I still replaced the cam and lifters but man, that sucks for ya
endeavor1 is offline
Old 09-30-2016, 04:20 PM
  #744
I never deemed anyone untouchable nor did I make anyone seem god like.
Black Baja is offline
  #745
Maybe we found his missing horsepower
  #746
SB
Received 3,233 Likes on 1,457 Posts
Originally Posted by MILD THUNDER
Not surprising....nice lobes he has.
Are you there at Tim's ?
I can't see extent of mark in my computer. How bad is it ?
SB is offline
Old 09-30-2016, 04:23 PM
  #747
I remove and install cams all the time and I can tell you that doesn't resemble an 8620 billet cam at all.
Old 09-30-2016, 04:24 PM
  #748
Received 1,494 Likes on 808 Posts
Port engine I bet.
getrdunn is offline
Old 09-30-2016, 04:29 PM
  #749
My guess is both will look the same. This isn't an anomaly or the first one like this. Quite common actually.
Old 09-30-2016, 04:37 PM
  #750
Thats the LS firing order cam he got from Bob Madera. Heres another one of bobs cams that was pulled out of an engine with 35 hours. looks like 8620 cam to me.
Attached Thumbnails Cam and valvetrain longevity....??? low duration high lift...-20160930_135146.jpg
