Cam and valvetrain longevity....??? low duration high lift... >
Old 09-30-2016, 04:43 PM
  #751
Received 4,813 Likes on 1,365 Posts
Lightbulb
What would it matter what side?
I think that is normal MK cam wear Tim.
Heads and Cam have to be tuned up every season. Try some 800 grit.
This is a Marine Kinetics cam after 35 hours, see normal.
Dammit Joe beat me to it.
ICDEDPPL is offline
Old 09-30-2016, 04:44 PM
  #752
Received 1,494 Likes on 808 Posts
Originally Posted by I.C.U.Lookin
My guess is both will look the same. This isn't an anomaly or the first one like this. Quite common actually.
Thought it might be why he had to lean that side down. Wasn't getting as much duration.
I'd confirm 100 % seat and open pressures all good and no coil bind. Then probably making a phone call or going for a drive with cams in hand.
getrdunn is offline
Old 09-30-2016, 04:51 PM
  #753
My crower cams or your crane 8620 billets didn't look like those, and they've been around the block quite a few times.
MILD THUNDER is offline
Old 09-30-2016, 04:53 PM
  #754
ICDEDPPL is offline
Old 09-30-2016, 04:55 PM
  #755
Originally Posted by MILD THUNDER
Thats the LS firing order cam he got from Bob Madera. Heres another one of bobs cams that was pulled out of an engine with 35 hours. looks like 8620 cam to me.
That is definately 8620
Black Baja is offline
  #756
I'd hate to see his lobes if he was spinning more than 5400rpm.
Old 09-30-2016, 04:56 PM
  #757
Obviously you want to cover all avenues. However this not being the first or an abnormal ordeal kinda lends to what the issue is.
Crude Intentions is offline
Old 09-30-2016, 04:59 PM
  #758
Right looks like Tim's is a 5150 which is a cheaper core.
  #759
Mine have a little mark. Can you feel anything with your finger Tim or are you too busy kicking the dog and throwing tools??
ICDEDPPL is offline
Old 09-30-2016, 05:01 PM
  #760
It`s probably not even A Marine Kinetics Cam.
Tim!!????!? WTF!?
ICDEDPPL is offline
