28 daytona eliminator and procharger fitment
I have a 99 28' tall deck with twin 572's. Does any one know if a m3sc procharger will fit on the port motor and clear the side of the hull. I want to put prochargers on the boat but not for sure it's going to fit. I looked at the dimensions on their website and it looks like it's going to be very tight based on my measurements. Anyone ever done it, or know of a boat with them? Thank you!!!
dont have your boat, but here is a shot of a M3SC on my old checkmate, give a idea of location..
http://s227.photobucket.com/user/ezs...a0bfb.jpg.html
Indy, the side of my hull has a contour to it. Depending on how high the blower actually sits may make or brake this setup. According to Pro Charger's web site the widest part of the setup is the center of the blower case itself. Would you be able to measure from the center of your crank straight up to where the center of your blower would be if you drew a straight line across to the center of the blower. I hope that makes sense......
I loved my M3SC procharged 500EFI's and think centrifugal superchargers are as good as any!
But I don't like them when used on blow thru carbs for some reason, seems like they only work with low boost.....and I know you wont be happy with only low boost :-)
Stick with your original idea of roots on top, you already have the blower scoops!
