Promaxx 320 flow numbers
#261
Those exhaust numbers can't be correct are they? Those are as high as a typical intake runner at that level. Did Jim split the intake and exhaust numbers by mistake, when really, those are all intake numbers?
#263
[QUOTE=getrdunn;4588125]Jim got back on my heads between projects. He's not done yet but txt over some numbers Saturday.
.200-157
.300-240
.400-315
.500-370
.600-404
.700-424
.750-431
Raised the floors. (Corrected on 10/29/17)
Should have exh this next week.
.200-157
.300-240
.400-315
.500-370
.600-404
.700-424
.750-431
#266
Mike knew I misprinted but wanted to make note of it and have a little fun at the same time.
I noticed the promaxx 340 cnc head which probably has same exh port as the 317's flow like 300 @ 700 so I'd say very similar although the same 340 cnc head intake flows 398 at same lift. I'd like to see 315 @ .700. I recall Jim not real pleased with the out of the box exhaust numbers. If he can work his magic on those as he did the intakes will be a big thumbs up. At the very least more options regarding aftermarket.
#267
Here's a their 340 cnc head flow numbers below:
Specs:
2.300"/1.880" valve sizes,
121cc-127cc chambers(Your Choice)
340cc Intake Runner
Flow Specs @ 28" w/2.300"/1.880" w/30* Backcut valves
.200" .300" .400" .500" .600" .700" .800" .900"
Intake 172 267 318 358 383 398 409 413
Exhaust 139 190 236 265 285 300 304 307
ProMaxx BBC 340cc CNC Ported (Bare Heads)
Specs:
340cc Intake Runner
