Carb question. 850 vs 800
#61
Update.
Fired up. Runs/idles like a champ.
Have a small fuel leak from the front accelerator pump. Took the bowl off and retightened everything but didnt have a chance to start it back up. I read that sometimes the screws can bottom out so u cant get them tight enough. If it still leaks next time i will try another gasket.
So far the only changes ive had to make are a choke adjustment and float level adjustment
Idles great and throttle response is good.
#62
Still havn't been able to start it back up to vetify if its still leaking but i figured id order a spare accelerator pump just in case. I couldnt tell exactly what i need
https://www.quickfueltechnology.com/...arburetor.html
This is the exact carb i have but i had to buy new fuel bowls since i striped threads in one of them.
Any idea what i need?
